ChrisXF wrote on 2023-11-12, 21:33:
I gave it a whizz from 33mhz to 40: that worked fine, but the moment clock doubling was switched on it hung. Next thing I need to try is upping the voltage a wee bit.
I'd really like to get an adjustable oscillator can made up with a PLL or something, to try all sorts of odd frequencies in small incremements.
The anyCLK device I am using can do that.
I also echo the above experience with clock doubling hanging my board. Mine is in the closet atm, haven’t messed with it in a bit though.
Feipoa, I think I recall you are using symphony chipset boards mostly? Trying to recall.
Could the issues be chipset centered in general? Or bios maybe?
I have pondered trying a mr bios on my board but haven’t tracked down a file I want to try yet (haven’t looked hard)
