First post, by egbertjan
Can an NVIDA Riva TNT2 Ultra 32MB from creative be installed in an ASUS P5A-B rev 1.04 with an AMD AMD K6-III+ 550 MHZ processor without destroying the motherboard? I have read that it uses too much power and damages the motherboard. Is this correct
Reply 2 of 5, by egbertjan
I don't have a power problem. I would like to know if I can safely put the NVIDA RIVA TNT 2 ULTRA 32MB in the AGP slot of the P5A-B rev 1.04 without breaking everything. I have an ATX 300 watt power supply in it. the NVIDIA RIVA TNT 16MB AGP and the NVIDIA RIVA TNT 2 MODEL 64 32MB work fine on the motherboard.
Reply 4 of 5, by Skalabala
You can use any AGP card on that board, I have gone up to FX5950 ultra.
Reply 5 of 5, by MikeSG
rasz_pl wrote on 2024-01-21, 20:20:
If tnt2 works then ultra should too, difference in power requirements were miniscule on the order of couple watts. But if it doesnt then solution is very simple.
The TNT2 Ultra is more like a detuned Geforce. 128bit memory, high CPU & GPU clocks
How can high load on the AGP port can damage anything? At most the PC will reset when running high power tasks.
