First post, by egbertjan
Can an NVIDA Riva TNT2 Ultra 32MB from creative be installed in an ASUS P5A-B rev 1.04 with an AMD AMD K6-III+ 550 MHZ processor without destroying the motherboard? I have read that it uses too much power and damages the motherboard. Is this correct
Reply 1 of 5, by rasz_pl
It takes one wire soldered between power connector and AGP slot to fix potential power problems as long as you are using ATX.
Reply 2 of 5, by egbertjan
I don't have a power problem. I would like to know if I can safely put the NVIDA RIVA TNT 2 ULTRA 32MB in the AGP slot of the P5A-B rev 1.04 without breaking everything. I have an ATX 300 watt power supply in it. the NVIDIA RIVA TNT 16MB AGP and the NVIDIA RIVA TNT 2 MODEL 64 32MB work fine on the motherboard.
Reply 3 of 5, by rasz_pl
If tnt2 works then ultra should too, difference in power requirements were miniscule on the order of couple watts. But if it doesnt then solution is very simple.
Reply 4 of 5, by Skalabala
You can use any AGP card on that board, I have gone up to FX5950 ultra.
Reply 5 of 5, by MikeSG
rasz_pl wrote on 2024-01-21, 20:20:
The TNT2 Ultra is more like a detuned Geforce. 128bit memory, high CPU & GPU clocks
How can high load on the AGP port can damage anything? At most the PC will reset when running high power tasks.
