I found a 775 to 478 adapter
First post, by Sphere478
Here you go, ask anything you like 😀
I am testing it in an ECS 915P-A motherboard.
Remind me, does this mobo only support pentium D?
Anyway, the adapter came to me with a special back plate with longer threaded sleeves and you have to remove the socket retainer. Past that, carefully install the heat sink, and it just works…
The pcb under it is very thick, idk how many layer, but I suspect a lot…
Sphere's PCB projects.
Reply 4 of 24, by Repo Man11
Interesting. But my mind misinterpreted what I was reading for a moment, and I thought "Socket 775 CPU in my P4P 800? That would be awesome!" Then I read it again.
Reply 5 of 24, by chinny22
Repo Man11 wrote on 2024-05-24, 02:48:
Same, wishful thinking I suppose
Reply 6 of 24, by myne
It's theoretically possible.
What you might be able to find that does exist is a 479>478 adapter.
Actually, thinking about it, I believe only a handful of pins were rerouted. Probably within the skills of someone here to remake it and get built by pcbway.
775>478 would take a fair bit more work because almost every pin would need to be routed, and then there's the mechanical side (hsf).
Things I built:
Mechwarrior 2 installer for Windows 10/11 Re: A comprehensive guide to install and play MechWarrior 2 on new versions on Windows.
Dos+Windows 3.11 auto-install iso template (for vmware)
Reply 7 of 24, by NTG2001
Wow this pretty neat... and cursed, but still really neat. I'd be curious to see what the compatibility with Northwood chips would be like. Don't know if the 900 series chipsets would still have compatibility built in, but Northwood would probably work on those 865 LGA775 boards though that kinda defeats the point.
Reply 8 of 24, by myne
I believe the chipset protocol is basically the same. Maybe a bit faster (Eg 133 vs 100) but the same language.
The only issue would be microcode, which comes down to the board maker, or a bios mod.
Things I built:
Reply 11 of 24, by Errius
Why would you want to put an older CPU in a newer board? Normally you would want to do the opposite.
Is this too much voodoo?
Reply 12 of 24, by The Serpent Rider
That's interesting for benchmarks mostly.
Reply 13 of 24, by Sphere478
NTG2001 wrote on 2024-05-24, 06:48:
northwood works fine, previous owner was using one in it with same mobo.
weedeewee wrote on 2024-05-24, 07:47:
What's the dip switch for ?
edit: it looks like a 12 layer pcb
Not sure, anyone have any infos?
Errius wrote on 2024-05-24, 09:31:
Perhaps you had invested in a p4 EE and wanted a newer mobo and this adapter was cheap?
The Serpent Rider wrote on 2024-05-24, 09:45:
P4 willamette aiming for the stars?
Reply 14 of 24, by The Serpent Rider
I doubt that many boards can provide required 1.75v for Willamette.
Reply 15 of 24, by Thandor
Interesting thing! At the very least you don’t have to consider changing your name to Sphere775 😀.
thandor.net - hardware
And the rest of us would be carousing the aisles, stuffing baloney.
Reply 16 of 24, by myne
Found the manual.
Barely readable, but it looks like the jumpers are for FSB setting.
https://blog.naver.com/spc9999/220932988338
If I'm reading it right.
Default on on
800fsb off off
Things I built:
Reply 17 of 24, by weedeewee
Sphere478 wrote on 2024-05-24, 12:08:
do a continuity measurement and see which pins/pads the dipswitch connects to.
Do not ask Why !
Reply 18 of 24, by deltapi
Were you able to boot? I think that board was supposed to do Pentium D and P4.
