Reply 60 of 112, by gerwin
- l33t
Would it be in adea to attach the image of the board to your posts? the sale will expire and then it is lost.
I've made Gl1zda the owner of the first post so he can work on it.
I need to move the photos over to Mediafire sometime. Imagebam is unreliable these days.
That is even better 😀
Imagebam unreliable, sorry to hear that. It was the image hosting of choice for a while.
wrote:Imagebam unreliable, sorry to hear that. It was the image hosting of choice for a while.
My images seem to slowly disappear from their servers. Sometimes the thumbnail remains but the original is gone.
Came across another intel microATX motherboard:
MU440EX
CPU: a single Pentium II (<=333MHz) or Celeron processor (<=400MHz)
Chipset: Intel 82440EX AGPset, 66 MHz host bus speed
Slots: 1 ISA, 2 PCI
Audio: Yamaha YMF 740-V
Graphics: ATI Rage Pro Turbo AGP with 2 MB SGRAM (option for 4MB?)
What image hosting service do you recommend? I assume the forum software can't do scaling?
EDIT: now it works.
I discovered that AN430TX AA revisions 672839-xxx does not contain onboard graphics and 680905-xxx does. Is it true?
Not long ago I got myself a PD440FX. YMF715 and no SCSI, only IDE as opposed to the first post
https://dl.dropboxusercontent.com/u/99196890/ … ns/P1020813.JPG
Most of the integrated devices (graphics, sound) were optional - Intel sold what the OEM wanted. I have a naked AN430TX and one with sound.
I also have an AN430TX with onboard Yamaha sound. It feels much snappier than the AT 430HX board with 256K L2 I owned back in 96-98...
17 years later I am finally able to build my dream Socket 7 system... 🤣
*αlpha*
Core i5 3570 - 4GB DDR3-1600 - Z77SL50K - GeForce GTX 560 Ti - 2TB HDD - Windows 7 Ultimate x64
*βeta*
Opteron 180 - 2GB DDR-400 - 2x GeForce 7800 GTX 256 - DFI NF4 SLI - 250GB HDD - Windows Vista
wrote:
403E is not 386 but 486 board.
See the CPU socket. And here is the best source:
http://web.archive.org/web/20041213005816/htt … esktop/archive/
I have an RC440LX running a pair of PIIs. It's interesting because it uses an unusual power supply with two connectors, one of which is physically (but not electrically) identical to the later 24-pin ATX standard. The other is a 14-pin auxiliary connector which I think carries monitoring/sensor data. It also has a standard 20-pin power connector enabling conventional ATX PSUs to be used instead.
ETA: There is a good picture of the R440LX motherboard with its original retail box currently on Italian eBay.
"This all reminds me when i took the windows vista sticker thingy off my old laptop, and on my washing machine as a joke. A few days later said washing machine stopped working. I still think this cannot be a coincidence."
wrote:"Hendrixx" (??) motherboard. Intel 430 LX (Mercury) with integrated CMD640 and Cirrus Logic CL-GD5434. AA 634444-201 Sister of t […]
Sister of the Batman and Premiere/PCI LC (Robin LC) AA 622319-402
Seeking for docs and BIOS upgrade.
Here it is some docs:
http://web.archive.org/web/19991022065631/htt … /PremierePCIlc/
And I have found the final bios package file (now this is the only one place where store this file):
ftp://ftp.ioncomputer.com/HardWare/SYSTEMS/19 … OS/10006BC0.EXE
wrote:403E is not 386 but 486 board. See the CPU socket. And here is the best source: http://web.archive.org/web/20041213005816/htt … […]
Well, the motherboard in the picture has a 486 Socket.
Just posting to show appreciation: thanks GL1zdA for this amazing resource!
I'm glad this thread got resurrected and I found my way here.
Outrigger: an ongoing adventure with the OR840
QuForce FX 5800: turn your Quadro into a GeForce
I got some retro intel branded boards
2x Advanced/ML, both have 4 pci, 3 isa, 256k cache, 430HX chipset
3x AN430TX, 2 of the boards with 4 pci, 3 isa without onboard video and 512k cache and the 3rd board with 2 pci, 2 isa with onboard video and no cache, 430TX chipset
TE430VX, with 4 pci, 3 isa, COAST module for cache sticks, 430VX chipset
AG430HX, with 4 pci, 3 isa, 256k cache, onboard ATI graphics and onboard yamaha opl3-sa sound. 430HX chipset
i used a couple of the boards that i have in a couple builds
Advanced/ML
Pentium 75
32mb RAM
Cirrus Logic GD5446
Sound Blaster Pro 2 CT1600
2gb CF Card
DOS 6.22 and WfW 3.11
AN430TX
Pentium 133
32mb RAM
s3 Trio 64v+
Sound Blaster 16 CT1740
40gb Maxtor 6E040L0 Hard Drive (this board supports over 8.4 gb unlike a majority of Intel 430 series chipset boards)
Windows 95 OSR2
Toshiba Satellite 200CDS
Toshiba Satellite Pro 430CDT
Toshiba Satellite Pro 480CDT
Toshiba Tecra 740CDT
IBM Thinkpad 760LD
Nan Tan(Clev0) FMA86T
wrote:Some soldering hacks regarding the SR440BX. This probably also goes for the other intel i440BX mainboards. Sources used: datashe […]
Some soldering hacks regarding the SR440BX. This probably also goes for the other intel i440BX mainboards. Sources used: datasheets.
Here is how to make a Slot-1 133MHz FSB Speed Pentium III EB work with the SR440BX, although it won't be running at 133MHz FSB.
Remove the resistor R19 on the slot-1 card, because otherwise the mainbaord will ground it through Pin A14. Then connect it to a 3,3V source at R18.
So There I have it my way: Running the SL3XG Pentium III 533 at 266MHz on the SR440BX.
About to do this mod to get a PIII-EB 1GH SL4BS booting on a Compaq branded intel 440bx. Does it default to 100mhz FSB or 66mhz (after removing R19 and connecting to a 3.3v source).
Is there any other non permanent way to force a P3-EB to 100hmz FSB by modding a 440bx motherboard instead?
From Intel 244452 P3E DataSheet.pdf:
Table 5. Frequency Select Truth Table for BSEL[1:0]BSEL1 BSEL0 Frequency0 0 66 MHz0 1 100 MHz1 0 Reserved1 1 133 MHz...BSEL0 = Finger/Pin B21BSEL1 = Finger/Pin A14...This signal can either be left as a no connect or tied to ground.It should be pulled up to 3.3 V with a 220 Ω resistor.
Since I only changed A14 it should be 100MHz with my mod.
wrote:Is there any other non permanent way to force a P3-EB to 100hmz FSB by modding a 440bx motherboard instead?
You can mod BSEL on the motheroard as well, but you are on your own then.
The cleanest way is to use a Slotket adapter with a Socket 370 CPU, then use the slotket jumpers to override BSEL.
