Intel-built 486/Pentium/PPro/PII motherboard guide
First post, by GL1zdA
ATX Note: Some (perhaps all) Dell ATX boards pre-Pentium4 have a proprietary ATX power pin-out. Any ATX PSU will plug in, but the board will burn up if you power up unless it's the Dell pinout.
http://pinouts.ru/Power/dell_atxpower_pinout.shtml
Intel iSBC 386AT-25
file.php?id=32677&t=1
486 Motherboards
Intel 403E
file.php?id=32678&t=1
Classic/PCI Expandable Desktop (Ninja)
- Socket 3, 420EX (Aries), Baby AT
Classic/PCI i486 (Alfredo)
manual PDF
- Socket 3, 420TX (Saturn), Baby AT
Pentium Motherboards
Classic/PCI Pentium (Batman)
manual PDF
- Socket 4, 430LX (Mercury), Baby AT
- There are a few versions of this board. Hard to find info. Some have SCSI onboard.
- ISA secondary IDE (fairly sure). Old-style direct mapped cache.
Premiere/PCI LC (Robin LC)
1.44 MiB
Premiere/PCI LC
Premiere/PCI II (Plato)
- Socket 5, 430NX (Neptune), Baby AT
- Very similar to "Batman" mobo but with the slightly different chipset and socket.
Advanced/ZP (Zappa)
[url=hhttp://www.mediafire.com/download.php?znwmzmnm115]Manual (doc)[/url]
- Socket 5, 430FX (Triton), Baby AT
Advanced/EV (Endeavor)
manual PDF
- Socket 5 or 7, 430FX, Baby AT
- Optional S3 Trio64 1MB (up to 2MB) and/or Creative Vibra 16S audio
Advanced/AS (Atlantis)
manual PDF
- Socket 7, 430FX, Baby AT
- Optional ATI 264CT video with 1MB (up to 2MB) and/or Crystal CS4232 audio
- A lot like Endeavor.
Advanced/ATX (Thor)
manual PDF
- Socket 7, 430FX, ATX
- Optional S3 Trio64V+ 1MB (up to 2MB) and/or Crystal CS4232 audio
- Seems to be Intel's first ATX mobo.
TE430VX (Tiger Eye)
manual PDF
- Socket 7, 430VX (Triton III), ATX
- optional S3 Trio64V+ 1MB (up to 2MB) and/or Creative Vibra 16C audio
AG430HX (Agate)
manual PDF
- Socket 7, 430HX (Triton II), ATX
- ATI 264GT graphics w/ 2MB EDO and optional Yamaha OPL YMF701 audio
TC430HX (Tucson)
manual PDF
- Socket 7, 430HX, ATX
- optional S3 Trio64V+ or S3 ViRGE with 2MB and/or Yamaha OPL3-SA and OPL4-ML (option)
Advanced/ML (Marl)
manual PDF
AN430TX (Anchorage)
manual PDF
- Socket 7, 430TX, ATX
- optional ATI Rage II+ and/or Yamaha OPL3-SA3 & OPL4-ML (option)
- optional video capture and TV-out
LT430TX (Lone Tree)
manual PDF
- OEM AN430TX w/o some options
Pentium Pro Motherboards
Performance/PR PR440FX (Providence)
manual PDF
- Dual Socket 8, 440FX, ATX
- Adaptec 7880 SCSI, optional Intel Etherexpress Pro/100B LAN
- optional Crystal CS4236 audio
Performance/VS VS440FX (Venus)
manual PDF
- Socket 8, 440FX, ATX
- Optional Crystal CS4236 audio
- some have USB
- I own one of these. A great Pentium Pro mobo that's very stable and even overclockable with an undocumented multiplier setting. Only downside is rather slow BIOS memory counting.
Performance/AU (Aurora)
manual PDF
- Socket 8, 450KX, ATX
AP440FX (Apollo / Krakatoa)
- Socket 8, 440FX, LPX
Pentium II Motherboards
PD440FX (Portland)
manual PDF
- Slot 1, 440FX, ATX. SCSI
- optional Yamaha OPL3-SA3 and OPL4-ML (option)
AL440LX (Atlanta)
manual PDF
- Slot 1, 440LX, ATX
DK440LX (Dakota)
manual PDF
- Dual Slot 1, 440LX, ATX.
- Adaptec 7895 SCSI
- optional Intel 82557 LAN and optional Crystal CS4236B audio
SE440BX-1 (Seattle)
manual PDF
- Slot 1, 440BX, ATX. Pentium 2 - 3 (Katmai P3).
SE440BX-2 (Seattle 2)
product guide PDF
manual PDF
- Slot 1, 440BX, ATX. Pentium 2,3.
- Coppermine processors on rev 754552-200 or later, 754558-200 or later, A01450-200 or later.
SE440BX-3 (Seattle 3)
manual PDF
- Slot 1, 440BX, ATX. Pentium 2,3. Coppermine.
- OEM only
RC440BX (Rochester)
manual PDF
- Slot 1, 440BX, uATX.
- Katmai P3 support on 718163-208 or later, 723888-205 or later, 724299-205 or later
- NVIDIA RIVA 128ZX w/ 8MB
- Sound Blaster AudioPCI 64V
SR440BX (Sun River)
promo PDF
manual PDF
Anandtech review (A-)
- Slot 1, 440BX, uATX. Pentium 2/3.
- NVIDIA RIVA TNT w/ 16MB
getquake.gif | InfoWorld/PC Magazine Indices
Reply 1 of 107, by GL1zdA
I still haven't found time to use my Intel 'Ninja' 486 motherboard. Does anyone know what for is this funny little PSU connector on this board? Also own 2 AN430TX, one with ATI onboard VGA and one without.
Reply 2 of 107, by swaaye
I'd say that's an aux power connector. I'm gonna guess that it's optional. Give it a try. 😀
There's something very similar on Intel ATX mobos rather often.
BTW, it would be cool to get a photo of that Ninja mobo so I can add it here.
Reply 3 of 107, by Old Thrashbarg
On my IBM, that extra power connector goes to the riser card, so I suspect it might provide power for the PCI slots or something. Supplementary power, maybe, to take some of the load of the main power connectors? Not sure, but it would make sense.
Also, with some of the ATX Intel boards you have to be very careful. The ones made for Dell, like many of the SE440BX-3's, have the same additional power connector, but it's for a proprietary Dell PSU, and that little connector carries the 3.3V lines. You can physically plug a standard ATX into the main power connector, but the pins are switched around in a non-standard layout, so you will fry the board if you don't use a Dell PSU (or an ATX modified to the Dell pin layout).
Reply 4 of 107, by swaaye
Ah yes that's right. I forgot about Dell's proprietary ATX power connections. The SE440BX that my brother had was one of those and I sold it with the PSU when it came time to upgrade. Will add that little tidbit.
I'm not sure if that started earlier than 440BX though.
As for that aux power connection, it looks like quite a few of the above Pentium mobos have it as well. And considering it's right up against the PCI slots, yup I think it's supplementary PCI power for whatever reason....
Reply 5 of 107, by Old Thrashbarg
It started back when Dell switched to the ATX form factor, in the late Pentium 1 era. I believe the Dimension P133 was one of the first.
Reply 7 of 107, by Amigaz
GL1zdA wrote:
http://img268.imagevenue.com/loc68/th_51976_IMG_4724_1_122_68lo.jpg […]
Snatched cache and Dallas DS rtc/cmos chip..."shivers" 😳
My retro computer stuff: https://lychee.jjserver.net/#16136303902327
Reply 8 of 107, by GL1zdA
Amigaz wrote:
GL1zdA wrote:
Snatched cache
I probably take some cache from another board. There will be only problem with the dirty bit cache.
Well, if you want an Intel mobo you have to accept them the way they are 😀
Reply 10 of 107, by retro games 100
The Tyan S1563D is a dual socket 7 processor mainboard, based on the Intel 430HX(II) chipset. Thought you might like to see a pic.
    84.44 KiB
Reply 11 of 107, by GL1zdA
Have exactly the same motherboard, but haven't had time to test it.
Reply 12 of 107, by Amigaz
mmm....dual socket 7 goodness 😁
*wiping the drool drips from my mouth"
Reply 13 of 107, by swaaye
Found a neat little Intel 440BX uATX mobo called the SR440BX. It has an onboard NV TNT GPU w/ 16MB and SB PCI 64.
added above
found 'em on ebay new-in-box for $20 + $10 shipping too.
Reply 14 of 107, by gerwin
That Ninja Mainboard seems like a great base for a 486 with PCI slots.
Also that SR440BX sure would make a nice and compact system 😀 Nvidia TNT graphics. ES 1373 sound on board, now I would rather have seen the Yamaha DS-XG, but you can't have it all.
What I kinda fear is that the Intel Mainboards, such as those based on the 440BX, have rather limited BIOS settings. I read about them having no FSB speed settings other then what the BIOS detects from the CPU: 66 or 100MHz. I would like to know for sure if they have any CPU multiplier options...
Reply 15 of 107, by swaaye
SR440BX manual
http://download.intel.com/support/motherboard … bx/73253401.pdf
According to the manual, when you jumper the board to configuration mode, you have access to setting up processor speed. It appears to have options for both 66MHz and 100MHz FSB, with CPU speeds from 233-500MHz.
I bet if you run a P2 Klamath that you can run it on any multiplier setting on 66MHz FSB. Good enough really.... A slotket is probably an option too, to force FSB.
Reply 16 of 107, by gerwin
That sounds good, thank you swaaye. Indeed certain slotkets can help to set 66 or 100MHz FSB regardless, but then you have to use a S370 CPU.
I also found the following line in the SR440BX bios update release notes: "Added processor speed selection capability for engineering sample processors." The Intel website states native support for processors up to 600 MHz with the latest bios. Still not sure if one can go below 233MHz...
Oh wait, I found it: "Clock multipliers from 3 to 5.5" so 200MHz is also possible.
Reply 17 of 107, by retro games 100
Has anyone seem this webpage before?
http://home.att.ne.jp/alpha/pcboard/486q.htm
It shows a whole bunch of 486 boards. They're not all Intel, so this thread is slightly off-topic, but nevertheless I think it's interesting.
Reply 19 of 107, by Anonymous Coward
I want to know where I can get one of these:
with matching CPU card:
0216NN.jpg[/img]
