Reply 8320 of 58438, by Stojke
- l33t
wrote:wrote:Most IDE VLB controllers have software drivers you can load (TSR) during autoexec.bat or config.sys that enable the cards to use VLB 32-bit for hard drive I/O
But DC-300 is an isa16 only scsi controller. They can't work faster, that isa itself.
Re: SCSI controller slow speeds
From my experience it did work faster. But I no longer have the card nor the board I used it in to test it with an benchmark program.
