Reply 10180 of 58450, by Skyscraper
Some time ago I won a boxed Digital Venturis 466 system but I have not had the time to open the box until now.
The DEC Venturis 466 is supposedly a 486 DX2-66, AMD or Intel, WB or WT with 128KB L2 cache on the motherboard or (most often) not.
Depending on the case size and riser version the system either supports 3 ISA slots on the riser and a low profile ISA slot directly on the motherboard or 6 ISA slots (5 on a riser and one directly on the board).
The onboard video chip should be a S3 Trio32 with 1MB memory soldered on the motherboard, sometimes with two sockets for upgrading to 2MB.
There are two versions of the motherboard but Im not sure if revison 2 ever was used in the Venturis 466, the only notable difference is that the 2.0 supports 256KB cache and has a 3.3V VRM.
In any case I opened up the box with the system today, when I opened up the case I diddnt find a DX2-66, I found a POD 83! 😀
Inside the Digital Venturis 466, A POD 83MHz and a Sound Blaster 16 SCSI CT1770 sitting on a "version 1.0" motherboard.
The attachment Inside_DEC_Venturis_466.JPG is no longer available
Under the SB16 we find a S3 Trio64 chip with 1MB memory and upgrade sockets and also sockets that can hold 128KB cache.
The attachment Inside_DEC_Venturis_466_2.JPG is no longer available
The system was sold as a "1991 386 system", almost correct labelling for a boxed Digital Venturis Socket-3 system with a POD 83 inside 😀
The price was ~33 euro on the Swedish Ebay clone Tradera.
Reply 10181 of 58450, by PhilsComputerLab
havli wrote:
PhilsComputerLab wrote:
7900 GTX SLI
Microstuttering generator. 😈
But, but it's about the frames! 🤣
YouTube, Facebook, Website
Reply 10182 of 58450, by Logistics
carlostex wrote:
http://i1286.photobucket.com/albums/a620/carlostex/speedstar%2024x_zps7sjeak6d.jpg […]
This was one of my first video cards, and I've kept it all these years, but months ago I went searching for it and could not find it. So frusrating! I hope I find it, soon.
Reply 10183 of 58450, by kixs
Is still remember what dumbass I was 😉 My 3rd video card was Tseng ET4000/w32. I sold it with my 386DX-40. Only to buy 486DX2-80 with ISA bus only and standard Tseng ET4000AX. It was all OK till I loaded Windows 3.1. It was slower then previous 386 🤣
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 10184 of 58450, by dirkmirk
Don't see these every day.
Reply 10185 of 58450, by rein_ein
Got this fat boy today its a Inno3D GeForce 6800 CoolViva Premium Edition
Not bought but traded for 256mb versions of fx5500 and radeon 9600pro
For tests i removed heatsink,coz noone of my mobos can handle such fatty,works well,but cant pair intel d850mv with this heatsink 😢
Reply 10186 of 58450, by sliderider
dirkmirk wrote:
http://i1216.photobucket.com/albums/dd361/dirkmirk/20160106_172620_zpstshtwxdn.jpg Don't see these every day. […]
Is that a Radeon 9100 PCI? Is it a Visiontek? The Visiontek cards use faster RAM than other 9100's and the cores on most 9100's can be cranked up to 8500 speeds or beyond.
Reply 10187 of 58450, by dirkmirk
It is a 9100 not sure what make but its a 64meg version, It did not work in my Pentium Pro motherboard but it did work in a socket 370 computer, I might put this in a PCI super socket 7 board but its complete overkill.
Reply 10188 of 58450, by nforce4max
pchips m919 ver 3.2 with a asynch cache module for $20 shipped but was doa /sad
Cyrix 5x86-100GP for $12 shipped but all my other boards are too old to safely test.
Reply 10189 of 58450, by joe6pack
rein_ein wrote:
http://i.imgur.com/q3QZQnll.jpg […]
Hey, I own that cooler! Mine is blue and branded by cooler master though. I bought it from either zipzoomfly or geeks.com a loooooong time ago. It's universal and a real nightmare to install, had it on a 6600gt for a while.
Reply 10190 of 58450, by Dreamer_of_the_past
Got this off eBay last year and it arrived today :) […]
Got this off eBay last year and it arrived today 😀
This is fairly new gear, but I have nothing that is SLI compatible. My only SLI experience is with 3dfx Voodoo 2 cards.
Let me tell you, I never had such a high end board. I always go for very basic and cheap uATX boards, so this was really treating myself 😀
This board is fully XP compatible and supports SLI as well as CrossFire. FX8350 CPU, but I can use my other AM3+ processor as well. And four 4 GB sticks of RAM.
I plan on playing around with SLI, always makes for a good video. Like 7900 GTX SLI for Splinter Cell Pandora Tomorrow?
Seems like people are gearing up for Oculus Rift.
Reply 10191 of 58450, by Sutekh94
Meanwhile, I'm gearing up for fun with a 386...
It's a Compaq Contura 3/25 with a 25MHz 386SL, 4MB RAM, 120MB HDD (noisy as crap but still seems to work fine), a slightly broken keyboard (some of the keys are dead), and, yes, a greyscale DSTN screen. Dead keys aside, everything seems to work fine!
My YouTube | My DeviantArt
Reply 10192 of 58450, by 386_junkie
Nice... I like it, a mini Compaq 386!
Might be worth trying electrical contact cleaner on those keys. If you get the little straw 'extender' for the spray nozzle and skoosh some under or into the key and then tap it repeatedly, or if you can get the key out... same deal but with a cotton swab.
Reply 10193 of 58450, by rein_ein
At least for now it will stay with 6800,finally got one working,probably will try with something like Asus P5P800-se
Reply 10195 of 58450, by Nvm1
Received my PT-319A 386 motherboard. It has damage from the leaking barrel battery but I hope I can remove the dirt/corrosion and that the motherboard still works. It has the Cyrix Cx486SLC2-MP50 cpu onboard. 🤣
Only other issue I found is that I lack decent vga cards for it. Only isa card I have left is a Trident 9000c with 512kb.. gonna search for a better 1mb graphics card. If anything reasonable priced can be found in Europe then give me a hint. 😀
Reply 10196 of 58450, by Mr_ppp
Bought this 'laptop' today!
Its an Amstrad ALT-386SX laptop
The attachment 12239965_10153449113077326_373023811872345397_n.jpg is no longer available
Amazed the chap was able to sell for £20 delivered, just awaiting its arrival
Reply 10197 of 58450, by easy_john
Long time don't have a free time to make a photos. Some boards received for last month:
A bunch of Creative boards:
IMG_8989.JPG.
2x Vibra16, 2x AZtech, some ess, noname adlib clone.
IMG_8990.JPG.
2x Voodoo2 12mb 100mhz, S3 Vision 968, Matrox Mil2, Tekram DC-690c (more or less - rare)
IMG_8991.JPG.
Adaptec 1542, SuperMIO VLB: CL5428 + MIO (MS3408).
IMG_8993.JPG.
Only one rare card - Synergy ViperMAX (GUS Extreme)
IMG_8992.JPG.
Pentium2 450/256mb/4gb/ati rage 128+voodoo2/SB awe32 8mb+db50xg/GUS PnP 8mb/TB Tropez 2mb
486 DX2-66/32mb/8gb/tseng4000 2mb/SB 16+WB/GUS 1mb/LAPC-I
286 12mhz/4mb/512mb/Vga 1mb/SB 2.0+Covox
PegasosII G4 / Amiga 4000 / Amiga1200 / Amiga 600
Reply 10198 of 58450, by brostenen
Holy shit.... Were on earth do you find all these kind of cards?
Reply 10199 of 58450, by Stojke
He who searches shall find 😀
