First post, by marquisor
Hi there!
I wonder what the correct settings for AMD-X5-133 on this board are?! I use it with a voltage adapter in CPU socket, not on the VRM. The CPU shows up as DX2 133 MHz, boots and all fine, but NO L2 cache is detected. After POST summary says "None", also speedsys doesn't show L2 in memory test.
Tried all possible jumper settings. The BANK 0 and TAG BANK is filled with cache chips. So it must have 128 KB L2 Cache.
I used this document: http://stason.org/TULARC/pc/motherboards/F/FI … GIO-VP-127.html
BIOS is from 1994.
Any hints?
Reply 1 of 1, by kanecvr
See if the chips are correctly inserted and oriented. A good picture of your motherboard would help.
