Red PCB RAM (simm72 or sdram)
Reply 40 of 48, by emosun
Now it needs one of these too
Reply 41 of 48, by luckybob
oh shit, totally forgot: http://www.ebay.com/itm/401297834107
That was on my search list. it is a hidden gem of a PSU (for its day). you need a psu with a massive 5v rail and features like -5v! This is a supply worth re-capping.
Reply 42 of 48, by Batyra
Wow, thank you guys for such interest and all the posts!
My goal is to make red build (or red & black). For socket 7 it is rare itself but I'm trying to use rarest parts I can find (red mobo, gus extreme, red ram - all qute rare)... I don't want to put inside everything that is red just because it's red. I also don't want any modding like painting etc - it's not my style at all. I'll also try to fit to the 2000 max.
@meljor - the buld is red and black co this one fits but I also have a red heatsink... but it's more Crimson than red 😒
@gdjacobs / Fresco - GUS extreme suport both SB and GUS - it works perfect in DOS - also with the easiest installation of all the GUS'es - if you ever installed Classic or PnP in DOS you know what I mean.
@peklop - one soundcard seems to be enough. thou I have almoaes all of the GUS but this one is rarest and works perfectly in DOS both as Gravis and SB. BTW there were no red voodoo cards ever 🙁 AFAIK
@luckybob - PSU - that red one is beautifull indeed - but I'm afraid it might be a little bit to new - have to think bout it - I'm a little broke right now after buying fev new Gravis cards... God they're so expensive 😒
I just collect the hardware — others make it run.
Reply 43 of 48, by gdjacobs
Is it complete or does it need an input filter can?
Reply 44 of 48, by Jade Falcon
Rank BANNED
BANNED
I vaguely recall seeing a red banshee before.
Reply 45 of 48, by luckybob
What?
Reply 46 of 48, by gdjacobs
Does it have an effective EMI filter, or is it incompletely implemented?
aHR0cDovL21lZGlhLmJlc3RvZm1pY3JvLmNvbS8zL0kvNTA5NDU0L29yaWdpbmFsL0NoYXB0ZXItNC1GaWd1cmUtMi1FTUlfZmlsdGVyMS5qcGc=
aHR0cDovL21lZGlhLmJlc3RvZm1pY3JvLmNvbS8zL0cvNTA5NDUyL29yaWdpbmFsL0NoYXB0ZXItNC1GaWd1cmUtMy1FTUlfZmlsdGVyMi5qcGc=
A missing or incomplete input filter stage is a sign of a gutless wonder.
Reply 47 of 48, by luckybob
AHH. I haven't torn one open in quite a while, but it does have filtering appropriate for the time. Its not going to be a 90%+ unit, but iirc it was good for the day it was built. I used one for my p4, but mine had the 4 fans and a mirror blue finish. I have a red satin one for my dual 900mhz p3 xeon. and it has run 24/7 for about 4 years before i retired the whole system.
Reply 48 of 48, by gdjacobs
Cool, thanks for finding it. If you have a chance, pop one open and take some pictures. In the meantime, I'll add this model to the PSU matchup thread.
