Red PCB RAM (simm72 or sdram)
Reply 40 of 48, by emosun
Now it needs one of these too
Reply 41 of 48, by luckybob
oh shit, totally forgot: http://www.ebay.com/itm/401297834107
That was on my search list. it is a hidden gem of a PSU (for its day). you need a psu with a massive 5v rail and features like -5v! This is a supply worth re-capping.
Reply 42 of 48, by Batyra
Wow, thank you guys for such interest and all the posts!
My goal is to make red build (or red & black). For socket 7 it is rare itself but I'm trying to use rarest parts I can find (red mobo, gus extreme, red ram - all qute rare)... I don't want to put inside everything that is red just because it's red. I also don't want any modding like painting etc - it's not my style at all. I'll also try to fit to the 2000 max.
@meljor - the buld is red and black co this one fits but I also have a red heatsink... but it's more Crimson than red 😒
@gdjacobs / Fresco - GUS extreme suport both SB and GUS - it works perfect in DOS - also with the easiest installation of all the GUS'es - if you ever installed Classic or PnP in DOS you know what I mean.
@peklop - one soundcard seems to be enough. thou I have almoaes all of the GUS but this one is rarest and works perfectly in DOS both as Gravis and SB. BTW there were no red voodoo cards ever 🙁 AFAIK
@luckybob - PSU - that red one is beautifull indeed - but I'm afraid it might be a little bit to new - have to think bout it - I'm a little broke right now after buying fev new Gravis cards... God they're so expensive 😒
Reply 43 of 48, by gdjacobs
Is it complete or does it need an input filter can?
Reply 44 of 48, by Jade Falcon
Rank BANNED
BANNED
I vaguely recall seeing a red banshee before.
Reply 45 of 48, by luckybob
What?
Reply 46 of 48, by gdjacobs
Does it have an effective EMI filter, or is it incompletely implemented?
aHR0cDovL21lZGlhLmJlc3RvZm1pY3JvLmNvbS8zL0kvNTA5NDU0L29yaWdpbmFsL0NoYXB0ZXItNC1GaWd1cmUtMi1FTUlfZmlsdGVyMS5qcGc=
aHR0cDovL21lZGlhLmJlc3RvZm1pY3JvLmNvbS8zL0cvNTA5NDUyL29yaWdpbmFsL0NoYXB0ZXItNC1GaWd1cmUtMy1FTUlfZmlsdGVyMi5qcGc=
A missing or incomplete input filter stage is a sign of a gutless wonder.
Reply 47 of 48, by luckybob
AHH. I haven't torn one open in quite a while, but it does have filtering appropriate for the time. Its not going to be a 90%+ unit, but iirc it was good for the day it was built. I used one for my p4, but mine had the 4 fans and a mirror blue finish. I have a red satin one for my dual 900mhz p3 xeon. and it has run 24/7 for about 4 years before i retired the whole system.
Reply 48 of 48, by gdjacobs
Cool, thanks for finding it. If you have a chance, pop one open and take some pictures. In the meantime, I'll add this model to the PSU matchup thread.
