Socket 7 (4x ISA)
First post, by Batyra
Hi folks,
as a soundcards collector I need many ISA slots in my socket 7 build. ATX format is also important because CPU socket in AT often collides with longer cards...
So I'm making a list of Socket 7 (and Super Socket 7) motherboards in ATX format with 4x ISA slots. If you have some ideas - please let me know.
So far we have:
1. Gigabyte GA-586ATX
2. Gigabyte GA-586ATX4
3. Asus TX97-XE
4. Asus TX97-X (XE but without simm / only dimm's)
5. Asus P/I-XP55T2P4 (430HX, 4x ISA)
6. FIC PA-2010+
7. FIC PA-2011
8. ITOX 586ITOX (430TX, 6x ISA !!! , onboard S3 Trio64V+ 1MB)
I'm also very curious was there ever a SIS based socket 7 board in ATX format with 4x ISA? That would be perfect for my Cyrix build...
Thanks for help.
I just collect the hardware — others make it run.
Reply 2 of 12, by shamino
[edit: added more info on the ITOX board]
DFI/ITOX G586ITOX/D (430TX, 6x ISA, onboard S3 Trio64V+ 1MB)
web page calls it a "586ITOX" but the PDF brochure uses the name G586ITOX/D which I'm guessing is more correct.
my notes had a link to:
http://www.itox.com/pages/products/mothers/It … b/itoxspec1.php
but that page is 404. It's in archive.org though:
https://web.archive.org/web/20120119003120/ht … b/itoxspec1.php
that page links to this PDF:
https://web.archive.org/web/20120328182421/ht … df/g586itox.pdf
Lists support for Pentium 233 MMX, K6-300MHz, and K6-2 266MHz at max.
It says Vcore options are 2.8, 2.9, 3.2, and 3.5v.
It was marketed for "telephony and industrial applications". It says all 6 ISA slots can hold a full length card, and from the picture that's apparently true. I've never used the board and don't know if there are any limitations using it with sound cards.
Reply 3 of 12, by Tetrium
Batyra wrote:
3. Asus TX97-XE
There's also the ASUS TX97-X, which is basically the same board, but which traded in the 72p SIMM sockets for another DIMM socket.
My retro rigs (old topic)
Report spammers here!
Reply 4 of 12, by Batyra
Nice, thanks guys - I'll update first post with your suggestions.
Reply 5 of 12, by lvader
Asus TX4P-X has 4 ISA slots, I'm currently using one with 4 ISA sound cards.
Reply 6 of 12, by bbuchholtz
Hey Guys,
I'm working on a similar project and stumbled upon this thread. I would like to use multiple sound cards in a DFI G586ITOX motherboard. Did you have any issues with using sound cards?
Reason I ask... I found this other thread regarding the DFI G586ITOX and 430TX chipset:
DFI G586ITOX motherboard? Opinions welcome!
According to the thread, it's suspected that the 430TX chipset uses 3.3V on the ISA bus, rather than 5.0V. I wanted to confirm if that was true. And if there were any sound cards not happy with 3.3V.
Here's the quote in question:
Since 430TX chipset motherboards work with 3.3 Volts on the ISA bus instead of the classic 5 Volts, some voltage critical cards (e.g. AVM Fritz! ISDN card) may be malfunctioning.
Any insights would be greatly appreciated!
-Brian
Reply 7 of 12, by The Serpent Rider
Hah! No.
Reply 8 of 12, by Anonymous Coward
M-tech R552 is an ATX socket7 board with *five* ISA slots. M-tech was all about the 5 slots, and you could find it on many of their boards for a time.
Reply 9 of 12, by bbuchholtz
I'm starting to think you have a penchant for M-tech. You seem quite fond of your R418W2 😁
I definitely like that the R552 has 4 PCI slots and the ATX form-factor is super convenient. Did a quick search and seems a little hard to find. I'll add it to my eBay search list.
I'm also considering this board: Mustang Ultra-R547
6x ISA and 2xPCI (1 shared slot). It's AT form-factor... but, I can live with that.
-Brian
Reply 10 of 12, by imi
why do ISA risers exist 😁
Reply 11 of 12, by bbuchholtz
I received my DFI G586ITOX today. It arrived sooner than expected.
So far, I'm really liking this board. I did a quick test with my DMM, and the power rail on the ISA bus is 5.0V. Also, I tested a few sound cards and they seem to work ok. Even my SBPro CT1600 is working just fine.
I updated the BIOS and installed a K6-II processor. So far, I'm having only partial success with K6-III+. The board POSTs ok... but booting to DOS is not so happy.
I have already found a couple of undocumented settings for this board. Officially, the board supports a Vcore all the way down to 2.1V. Which is suitable for K6-II. However, I was able to get this board down to 2.0V.
JP1: 1-2, 3-4, 5-6, 7-8
Also, I found some undocumented multipliers. Officially, the board supports 3.5x. I was able to get up to 5.5x. I have this baby running at 366MHz.
JP7: 5-6
-Brian
Reply 12 of 12, by Anonymous Coward
bbuchholtz wrote on 2020-07-09, 18:50:
I wouldn't necessarily say that I have a penchant for M-tech, but I am aware of their products because I owned an R534F when it was new, and I spent a lot of time on their website, ftp server and usenet group trying to sort out my problems. They had a couple of products that were targeted at people who moved components from an older build to a newer one, so that kind of made them cool. But...on other other hand, they also had a few stinkers. I don't think they were around very long before being gobbled up by Soyo.
BTW, my R418 is currently non functional. Bad solder joints on the chipset, and I need to invest in better tools to fix it. R418 is alright for the money, but there are better SiS 496/7 boards for sure.
