First post, by eric1992
I've seen a lot of guides on how to dual boot Windows 98 but that's with a single hard drive. Is there a way to do it with two hard drives without having to download some boot manager? I have Windows 98 SE installed on both drives.
Reply 1 of 7, by .legaCy
Dependong on the bios it will let you choose which drive will be booted when you press one key on post(usually f8), if the bios don't support i think that changing boot order in the setup is the way to go without any software.
Reply 3 of 7, by Flare
How about using CF cards in an IDE adapter on the front of your case?
That's what i use to switch between DOS and Windows 98 in my build.
I see one just like mine is for sale on Ebay: https://www.ebay.com/itm/ADTRON-3-5-ATA-to-ID … ER/202296947991
Or if you want a black one these work well too: https://www.ebay.com/itm/StarTech-com-3-5-Inc … er/192449282570
Both mount in a 3.5" bay.
Reply 4 of 7, by eric1992
That's very convincing. I'll look into it - though I'd have to get a 5.25 bracket for that since my case is kinda funny with the 3.5 drives. The hard drives go in the same area where the 3.5 floppy drive is.
Reply 5 of 7, by Flare
I had to 'adapt' mine to 5.25" as well.
If you have a Best Buy in your area, try seeing if they have 32GB Sandisk Extreme CF cards on sale for $32 instead of $80.
Mine still does: https://www.bestbuy.com/site/sandisk-extreme- … p?skuId=1923006
Reply 6 of 7, by Tiido
I installed a switch that swapped master and slave settings on the two HDDs, as BIOS didn't allow to change boot order. Touching that switch while system runs is a very bad idea 🤣.
Reply 7 of 7, by Vipersan
Hard to find these days ...
less so in the US ...
I had to import mine ..but opens up a world of possibilities with switched operating systems for old IDE drives.
I use mine in a 6 x OS tower ..which has 3 operating systems per drive (triple primary partitions)
and I can physically select which drive of the 3 prior to power up ..
I then use a boot manager to select the required OS on the drive selected..
I think one is currently being adverised for sale on Amazon..around 25 dollars used.
the :- ROMTEC RX-910T6 Romtec Trios
fits in a vacant 5.25 inch tower or dektop bay.
rgds
VS
    79.83 KiB
