First post, by sketchus
Hi folks,
Hope someone here can help.
I picked up an Iiyama Vison Master Pro 455. It's a lovely monitor and in great condition.
I have a bit of a weird issue though. I get severely crushed blacks when connecting it to my pc via a HDMI to VGA adapter. In the Nvidia Control panel if I shift it to RGB limited, everything looks correct. I currently don't have a direct VGA device so am forced to use the adapter.
The reason I query this is because as I understood it, monitors used RGB Full? I'm just wondering why I need to set it to limited to see the image properly.
Thank you.
Reply 1 of 3, by PTherapist
Could be the HDMI adapter outputting that way, rather than the monitor itself.
Reply 2 of 3, by oeuvre
Try connecting it to something through just a VGA cable... see if it is the monitor or the HDMI adapter.
Reply 3 of 3, by sketchus
Okay will do, my current retro PC is disassembled as I was going to get it recapped. I'm hopeful it's just the adapter doing it. I have an OSSC which if I set to output in YCbCr, it works perfectly. Must be the way the adapter handles the signal.
