First post, by sketchus
Hi folks,
Hope someone here can help.
I picked up an Iiyama Vison Master Pro 455. It's a lovely monitor and in great condition.
I have a bit of a weird issue though. I get severely crushed blacks when connecting it to my pc via a HDMI to VGA adapter. In the Nvidia Control panel if I shift it to RGB limited, everything looks correct. I currently don't have a direct VGA device so am forced to use the adapter.
The reason I query this is because as I understood it, monitors used RGB Full? I'm just wondering why I need to set it to limited to see the image properly.
Thank you.
