Reply 28400 of 58419, by appiah4
Both ISA sound cards have genuine Yamaha OPL3, the former due to having cloned Yamaha chips on board but being an ALS007 chipset card it may have filtering and noise issues (most cheap OEM cards using this chipset do), and the latter due to having a yamaha chipset, YMF-71X. Both cards have wavetable daughterboard haders and the ALS card has IDE connectors as well. Overall, they are pretty good cards to have; especially the ALS007 due to being one of the few chipsets that are SB16 compatible - so it is probably the most bugfree SB16 (clone) you can find around.
Reply 28401 of 58419, by retropol
appiah4, thanks for valuable comment. Hope I will be able to build something interesting from all this stuff, goal is to recreate 2 machines from my times...
- 486dx2 66 - it was about 1993-94
- pentium 200mmx - it was somewhere 97-98
especially 486dx2 was magic... jumped from commodore world into pc world (escom pc).
Reply 28402 of 58419, by liqmat
I think a lot of us Amiga freaks jumped to PC around the time we saw Doom and knew Commodore was headed in no direction at all. I jumped in with a 486 DX-33. Never looked back, but I will never forget the butterflies in my stomach when I first turned on my Amiga 1000 back in 1985. It had its time.
Reply 28403 of 58419, by Predator99
Won this auction for 5.50 € incl. shipment (sellers photo)
The attachment s-l1600 (1).jpg is no longer available
Not really interested in these modern PS/2 RAMs, but I spotted some 30 Pins inside which are rather hard to get for a good price.
And indeed, I received about 10 of them along with these 2:
The attachment DSC_8500.JPG is no longer available
These are 16MBs 😎 Dont know where to use 2 as you ususally need 4 but maybe I have a Soundcard which accepts them...
Reply 28404 of 58419, by rikukos
jheronimus wrote:
rikukos Great machine!
Thanks buddy!
SpectriaForce wrote:
Maybe a Rendition Verite card would be nice for this puppy.
Hey, what a nice idea - Verite didn't even come to my mind. Now if I only had something Verite based..found this one at the top of the pile which I could sacrifice 🤣
roq8487m.jpg?1
Reply 28405 of 58419, by dirkmirk
kixs wrote:
Some quick test I've done between PPro 200MHz 1MB cache and socket 8 Overdrive P-II 333MHz. […]
DOOM:
PPro... 1070 realtics
P-II... 931 realtics
CPUmark32:
PPro... 23
P-II... 27.3
But these are all 32-bit programs 😲
I don't think I used FastVid on any test. Might redo tests on this behalf 🤣
Pentium(PRO) 2 Overdrive 333 BEAST
Results ive seen.
Despite the 60% increase in clock speed + full speed 512kb level 2 cache you dont gain as much with the overdrive 333, this was tested with a motherboard that doesnt have memory timing settings so that could be holding it back.
Reply 28406 of 58419, by luckybob
@kixs
Try swapping to a video card that supports USWC, and make sure its enabled in the bios. You will like the results.
Here's why: The Ultimate 686 Benchmark Comparison
Reply 28407 of 58419, by Intel486dx33
Predator99 wrote:
Won this auction for 5.50 € incl. shipment (sellers photo) […]
I am sad because I have lost my bag full of 30 SIMMs. They are somewhere in my mess of a garage.
So now I have to buy new ones.
8mb. is really all you need ( 2 x 4mb. sticks ).
16gb. = ( 4 x 4mb. sticks ).
Reply 28408 of 58419, by mothergoose729
I bit on a listing for 2 untested 754 boards a while back. One board had 256mb of memory with a sempron, and another had 1gb of DDR with what was listed as a 3200+. Neither board would post, so I threw out the motherboards and kept the 3200+ and memory for a rainy day. Sometime later, I bought an Asus 754 board with a 3000+ on ebay. It was the model clocked at 2.0ghz with 512kb of l2 cache. It worked great and I have been using it ever sense.
Today I want into my garage to grab the 3200+ I got with the busted motherboards. I was hoping to get the 2.0ghz model with 1mb of l2 cache. Looking at the model number I saw a 3400 instead of a 3200. Excited I googled the model, and it's an athlon 64 3400+ with 1mb l2 cache! The second fasted CPU released for the socket! These CPUs usually go for about 50$, so suddenly what looked like a complete bust turned into a pretty decent score. I have it clocked at 2.3ghz right now and it is looking pretty stable, not to bad at all!
Reply 28409 of 58419, by SpectriaForce
rikukos wrote:
Thanks buddy! […]
Thanks buddy!
roq8487m.jpg?1
Another 'alternative' card would be a Voodoo Rush. Try to create something different. So many people over here already have a Voodoo2 setup.
Reply 28410 of 58419, by c0keb0ttle
I've been looking for one of these for years!
Finally found one locally, and it's now all mine, and at a decent price too!
The attachment Roland.jpg is no longer available
Reply 28412 of 58419, by Daniël Oosterhuis
Went to a fleamarket this morning, saw somebody selling some computer parts and a NVIDIA card caught my eyes. Yes, it was a FX 4500 as I thought! Snatched it for €5, went home, and flashed it with a PowerPC ROM. Now my PowerMac G5 Quad has a nice upgrade over the GeForce 6600 it came with 😎
Image removed for copyright reasons.
Reply 28413 of 58419, by cyclone3d
I bought a Voodoo Rush back when they were still being sold in stores. I returned it 2 days later and got a Banshee instead because the Rush was so slow.
A Rush is about the same speed as a Voodoo 1. The Banshee is about the same speed as a Voodoo 2.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 28414 of 58419, by cyclone3d
arncht wrote:
how good is it compared to the mt32? does it work with the sc55 in daisy chain?
It is the same as an MT-32 new version. Yes you can daisy-chain. The MPU-401 port is also an intelligent mode port so you could hook up another MT-32 or MT-100 to it.
YMF7x4 Guide
Reply 28415 of 58419, by yawetaG
Also went to the King's Day flea markets, skipped a Thrust vintage joystick and various older (but very common) hardware, and then, just as I was starting to wonder whether there was anything really interesting, I walked past a stall that had a Roland keyboard sitting there. Glanced at it, thought "Nah, can't be for sale, probably the kids will start playing on it later", walked on, then went back and still asked "That keyboard probably isn't for sale, right?".
Result: 1 working Roland JV-35 Expandable Synthesizer with power supply for 40 Euro... talk about a score. 😎
The JV-35 is something of a Super Sound Canvas:
- GM/GS-compatible sound set using the JV-80 synth engine and a 61-key velocity-sensitive keybed with aftertouch,
- limited edit from the synth itself but many more parameters via sysex,
- quite nice master keyboard setup options (such as keyboard split, dual mode, fattening up the sound by layering octave-shifted sounds, etc.),
- plus an expansion slot on the bottom for one expansion board, with choice of doubling the GM/GS capacities for extra fat sound, or gaining the JV-80/90/1000 sound set and parameter edit(!), depending on the expansion board used. I've ordered the second expansion board now, too. 😀
Getting the thing back home by bike was somewhat of a pain though. 😵
So, in 2017 I got a 1980s Yamaha PSR. 2019 brings me a semi-pro synth. 2021 = ???
Reply 28416 of 58419, by c0keb0ttle
It's basically an MT-32 on an ISA card. It's exactly the same sound-wise.
I haven't tried hooking up an SC-55 to the MPU port yet.
Reply 28417 of 58419, by Bige4u
My VooDoo AGP versions collection is now complete!
Voodoo3 2000 / Voodoo3 3000 / Voodoo4 4500 / Voodoo5 5500
Pentium3 1400s/ Asus Tusl2-c / Kingston 512mb pc133 cl2 / WD 20gb 7200rpm / GeForce3 Ti-500 64mb / Sound Blaster Live! 5.1 SB0100 / 16x dvdrom / 3.5 Floppy / Enermax 420w / Win98se
Reply 28418 of 58419, by bjwil1991
Bought the following from 4/26-4/27:
Gravis Blackhawk (not digital)
Sega Genesis Model 1 High Definition Graphics model
4.1 Surround speakers (complete in box)
The Genesis needed some TLC to get the system to load cartridges, and fortunately, no broken pins and everything is still good. Might do a recap sometime soon, and I had to buy a power adapter and AV cable to test it to make sure it turns on and it does indeed work.
Reply 28419 of 58419, by liqmat
I used to have a large collection of titles for the Genesis. The rare ones went to a museum and the rest I sold off. One of my favorite titles for the console is this and I highly recommend it. Especially two player is a lot of fun. Pounding soundtrack as well.
https://youtu.be/GRV8jwEfUrs
The biggest weakness of the model 1 is the cart slot.
