First post, by retropol
anyone can help in getting drivers for windows 3.11 and/or dos. Wondering in under dos is any software which can use this equipment.
Was there any dedicated sofrware for such hand-scanners?
https://fccid.io/EMJSE401A
Reply 2 of 8, by Grzyb
Primax Hand Scanner... but which exactly?
I have the software for "Primax Color Hand Scanner", but no idea if it's the same model as yours...
    primax.rar
    3.99 MiB
    43 downloads
Reply 4 of 8, by Grzyb
OK, I've found that scanner, unfortunately, it's a completely different model, with a different interface card...
    86.02 KiB
    34.68 KiB
    52.67 KiB
Reply 6 of 8, by lolo799
Found the following on driverguide, which are older than your drivers.
They are for more than one model:
File README.TXT for InterPreter package […]
last revision date : 19 august 1993
Contents : informations for scanner configuration.
CONTENTS :
- distribution diskettes
- general notes about scanners and drivers.
- Primax Infoscan SCA04
- Primax Infoscan SCA04.1
- Primax SPI scanners
- Primax TWAIN scanners (Color/Grey Mobile)
Primax Handy Scanner.zip
2.5 MiB
38 downloads
https://www.driverguide.com/driver/detail.php … 60c174fb01a60ed
