First post, by retropol
anyone can help in getting drivers for windows 3.11 and/or dos. Wondering in under dos is any software which can use this equipment.
Was there any dedicated sofrware for such hand-scanners?
Do you have a picture of the scanner and the interface card?
Primax Hand Scanner... but which exactly?
I have the software for "Primax Color Hand Scanner", but no idea if it's the same model as yours...
Nie rzucim ziemi, skąd nasz root!
Grzyb, thx, do you have any manuals or smth ?
OK, I've found that scanner, unfortunately, it's a completely different model, with a different interface card...
Primax here has a similar IC:
http://oldcomputer.info/pc/apscan/index.htm
Found the following on driverguide, which are older than your drivers.
They are for more than one model:
File README.TXT for InterPreter package […]
last revision date : 19 august 1993
Contents : informations for scanner configuration.
CONTENTS :
- distribution diskettes
- general notes about scanners and drivers.
- Primax Infoscan SCA04
- Primax Infoscan SCA04.1
- Primax SPI scanners
- Primax TWAIN scanners (Color/Grey Mobile)
https://www.driverguide.com/driver/detail.php … 60c174fb01a60ed
hey, do you know what the settings for the jumpers are?
still fighting with the setup, dont know the meaning of the jumpers
internals of the scanner:
