Reply 12540 of 30908, by oeuvre
- l33t
also make sure you refill the PSU fluid
Hmm, thanks for the warning. I didn't think it would make a big difference, tbh.
The old one has something like 6.9 cfm over the Noctua's 4.8, but then, there's no great loads on this PSU.
Maybe a good idea to just monitor the temperature for a while. I was actually planning on putting in an additional case fan to help with overall cooling, that might offset things.
when I got this case the CD drive was jammed into the case, including the drawer mechanism, forgot to take a picture before... only took one after I aligned it...
had to pull out the drawer with a flat piece of metal:
the open/close latch was jammed, so I opened the drive and almost lost the tiny bearing balls that came falling out ^^... the magnet inside with the metal clips came loose and somehow got jammed inside the plastic housing, after pulling it out and aligning it again it seems to work fine 😀
and did a quick cleanup, that's one happy 1992 CD-Rom drive 😀
wrote:when I got this case the CD drive was jammed into the case, including the drawer mechanism, forgot to take a picture before... only took one after I aligned it...
That PC case is really nice.
it is indeed, my first desktop case, I like the "car hood" like opening mechanism ^^ and if that wasn't enough it also came with that odd but awesome mitsumi drive.
Saw the new Rocko's Modern Life special on Netflix. It was amazing, especially if you grew up watching the show.
wrote:wrote:when I got this case the CD drive was jammed into the case, including the drawer mechanism, forgot to take a picture before... only took one after I aligned it...
actually I had a similar one and the build quality wasn't great - thin metal and lots of flex. I don't know if yours is built any better?
Love the hood though!
wrote:I'm sure someone would have use for the remains...
If someone is interested in a free Diamond Monster 3D Voodoo with a missing capacitor, then let me know. I still have it.
wrote:wrote:I'm sure someone would have use for the remains...
I would take it, but you should know, that is five minutes and a capacitor away from being worth 80$-100$ USD 😉
wrote:wrote:wrote:I'm sure someone would have use for the remains...
Depending on what type and which capacitor it is, that may not be a job for a novice with solder.
wrote:wrote:wrote:If someone is interested in a free Diamond Monster 3D Voodoo with a missing capacitor, then let me know. I still have it.
Although even a novice with way too gratuitous amounts of solder can easily "blob-botch" one of these if capable of a half-steady hand, which would result in a working albeit ugly result, I do agree.
If you're serious on that, I'd be on that immediately, sounds like a fun repair project to me!
Send me a PM if you want to collect it or contact me via my website.
wrote:actually I had a similar one and the build quality wasn't great - thin metal and lots of flex. I don't know if yours is built any better?
I wouldn't say build quality is great... the metal isn't really thin as such but yes the whole case flexes quite a bit when open because the whole case is just held together by one big U-shaped metal piece (I guess it'd be better if I had it standing on a stable surface), also the whole case is a bit "ouf of shape", but eh, I still like it 😀
The CD drive must be a Mitsumi CRMC-LU005S.
I'm making RAM sticks ~
wrote:wrote:wrote:I had been reverse engineering the jumper settings for a MHz display in one of my cases, but I could not get one of the segments to work. I had concluded that the segment must be defective 🙁
Today I desoldered it from the PCB (nice first job for my new desoldering station), and tested it. The segments LED is indeed not working 🙁 Unfortunately it's the middle horizontal one, so I can only make a 1 or a 7 now 🙁
I wonder if I can find a replacement. Finding the data sheet for the display unit was surprisingly easy (and very helpful).
Those 7 segment displays are usually standard off the shelf stuff. Shouldn't be hard or expensive to find a replacement 😀
If you can't find a 2 digit one, I'd guess two 1 digit ones would be fine too. The pin configuration on those displays seems to be pretty standardized.
I have been looking for a replacement last night, the pinout seems standard, and so does the voltage (if I pick the same color). Now finding one (or two) for a decent price (including shipping) is a bit harder. Replacing it with two 1 digit displays seems impossible, it has 2x 9 pins. Will continue the search today.
If you're in the GTA, I know where to get these for pennies. Old school ones too.
What's for sale? my eBay!
So I got myself a C64!
This would not be my first one, probably like the 5th or 6th if you count VIC20 machines, but I want to keep this one for a bit and actually learn how to use it and program on it. I will need a better solution for a monitor, but for now it's connected to a cheap-as-free 14 inch TV VCR combo.
In taking steps to preserve it, I've hacked up an old 486 CPU cooler as well as one from a Pentium, and set on epoxying the bits of heatsink to the most prominently heat prone chips in both the main unit and the 1541 (with a 1541C drive swapped in, faceplate and all)
A tribute to the cooler that gave its life:
This one is actually just heatsink compound:
Main system board:
Floppy drive:
I will go add one more sink to the rectifier diodes in the floppy drive before my epoxy dries out.
Next step is to clean it up a little more, wait for my XM1541 adapter to arrive, and start using this thing!
That and figure out a better way to output. I see some people connect LCDs to these, do I have to use an expensive scaler, or is there another way?
Making heatsinks from a 486 and Pentium cooler for the Commodore 1541 and 64 are amazing. I need to start doing that for my C64 sometime soon and find a 1541-II diskette drive, then swap the KERNAL ROM for the diskette drive from CBM to JiffyDOS for faster load times and a datasette. I wonder if the local video game store has any Commodore systems, accessories, and games? I would love to grab copies of games for the datasette as I admire the loading sequence they have, diskettes of the games, or cartridges. I have a couple of Atari joysticks that I can use for the C64, and I wish that someone can port the Sierra quest games, like Police Quest, Space Quest, King's Quest, and Leisure Suit Larry (EGA version) for the C64 someday so the joysticks can be used to control the characters and entering the commands from the keyboard.
I had a friend come by to check out a couple 486 machines he was interested in, and despite them both working OK the last time I tried them out, OF COURSE they had a bunch of brand-new issues when we went to get them going. He stayed around for an hour & we tried to sort them out, but no luck. Now there's boxes of parts and opened systems all over my living room again and I have to spend the rest of the evening putting it all away. AGAIN.
I think it's time to flog pretty much everything I own that's pre-ATX. It's just not fun to mess with this stuff anymore. Spare parts are too hard to get & there are too many issues that should be "easy fixes" but leave systems in pieces on my bench for weeks. Pentium IIs and Athlon XPs "just work" for Win9x and I can't think of a single DOS app I'd want to run that's too speed-sensitive for my P233MMX (and DOSBox works great for those.) Somebody else's turn to get headaches from this lot.
