First post, by svfn
- Member
Hi there, I used Delpart to erase partitions on an old 5GB drive and during Win98SE installation, I chose to let it allocate all space on the unpartitioned drive and it created only a 2.92GB FAT32 partition as C. I ran fdisk again and it showed 1 active FAT32 partition as primary DOS partition with size of 4887 MB, and the usage is 100% on a fresh installation?
The reason I used Delpart was because previously the disk had an extended DOS partition of 1883 MB in addition to active FAT32 partition of 3004 MB, and I could not delete the extended DOS parition with Fdisk. Delpart also only showed the 1 active partition if I remember correctly. Should I reformat it to recover that missing space?
edit: fixed after redoing fdisk and reinstall 98se.
