First post, by LeFlash
- Member
Hello,
someone having a copy of je4333apm.zip?
Its a modified beta-bios from FIC for the VA503+ with K6-III+ Support and up to 60GB IDE drives.
Can't find a copy of it anywhere on the net 🙁
Kind regards!
Hello,
Kind regards!
I'm not finding the APM version anywhere, but the standard je4333 version is available.
Is there a specific reason you want the APM only version (ACPI option rom stripped out)? Only reason I see for that is if you want to run XP.
The regular version supports K6-2+/K6-3+ CPUs as well as large drives.
The only difference is the stripped ACPI? Ok, i can do this myself.
Thank you for this information!
Got hold of this board today and was immediately happy because i used this board a lot that time.
It's revision 1.0A and has a 4.7k resistor between Vss and NMI on the socket, i'm not sure if that's a factory or user mod.
Yeah, only difference is ACPI stripped out from what I could find... at least that is what the person that made the original modded BIOS said in the posts I found.
Sorry tk revive this old thread but I'm looking for JE4333apm. Seems impossible to find. I really want to stick with the AT powersupply for my va503+ mb.
Seems lost sadly - the closest I could find either online or in my own files is the previous APM version JP4329, which doesn't support K6-II+ / K6-III+ 'mobile' CPUs or 60GB drives.
Model - VA-503+ […]
Model - VA-503+
BIOS Maker - AWARD
Fixes - fixed AT power supplies were unable to complete system shut down under WIN98
Notes - for AT Power Supply user only
Status - release
If you're handy with BIOS modding tools you could probably replicate the work of Tim Stinnett (as user 'tcsenter', the modder who created JE4333APM) - here's a link to a thread where he mentions his work.
https://forums.anandtech.com/threads/o-mother … ng-down.719618/
Thank you for looking.
I've been experimenting with using awards tool - cbrom.exe, however I'm thinking there is more to the process than just removing ACPITBL.BIN from je4333.bin. I've actually done it and I 'may' try flashing it. I see many people using cbrom.exe to modify boot logos.
http://www.captainwilliams.co.uk/root/fic503.php
MODDED BIOS BY Tim Stinnett, IMPOSSIBLE TO FIND, BUT I FOUND IT, AND SHARING WITH ALL OF YOU
Blast from the past - hilarious! For posterity, in addition to the file contributed by SETBLASTER:
je4333APM.zip for FIC VA-503+
