First post, by alfer
So I finally had it with procrastination and having all the hardware on hand decided to build my 3-year overdue DX66 machine.
My current pick is Shuttle Hot-419. It is Opti-based and has a welded coin cell rechargeable battery (not from factory, though some revisions do have an actual battery holder). Nice one overall, but I would really like to start it off with SiS. SiS with Amibios WinBios 2+VLB and CR2032, to be exact.
The problem is I'm unable to find (the facts of existence of) anything decent other than ever so popular AOpen VI15G.
And on the topic of indecent there are only 2 other candidates, according to elhvb:
I would probably bite the bullet and buy VI15G if it's the only real option out there. A few nays - want it to be dated =<94 (likely not the case here), annoyed by the soldered molex connector, don't like Acer all that much.
Reassuring suggestions are appreciated! Hard truths as well.
UPDATE
With the help of Deksor's wonderful Ultimate Hardware DB 2019, elhvb, an obscure japanese webpage http://home.att.ne.jp/alpha/pcboard/486.htm and google I was able to greatly expand the list. Keep in mind that it's not by any means complete, as even somewhat documented boards often do not show the battery in it's diagram and don't have a single searchable photo. I would expect that some of the Phoenix mainboards could come with AMI Bios as well (and vise versa) and have different kind of RTC battery, depending on revision.
1. VLB SiS AMI CR2032:
Acer V433S
AOpen VI15G 486 - duh!
ASUSTeK VL/ISA-486SV2B
AUSTIN COMPUTER SYSTEMS 486 LX VESA LOCAL BUS WINSTATION
CMC C4PI REV A01
J-403TG V2.0
S486G Green Motherboard
2. VLB SiS AMI DALLAS:
486MIS REV 1.01
BCM LX400A/G
BCM LX400A/P VLB
DTK PKM-5037S (VER. 2.00)
ECS SL486VE
NORTHGATE COMPUTER SYSTEMS, INC. NORTHGATE ENERGY STAR LX400A/G REV. 3.1
Tyan 486VL EISA VESA LOCAL BUS (REV. 1.0)
Could be useful to someone.
Reply 1 of 14, by Deksor
There must be some other boards available, but they're rather uncommon indeed. Check uh19 for boards that match your expansion slot criteria and look if you find any board with a cr2032 battery holder
Reply 2 of 14, by computerguy08
I own a J-403TG v2.0, which you can find here.
It's powered by an OPTi 82C895, works great with DX2 and DX4, even 5x86 chips.
To get 3.3V chips working, you need to do a little mod (which I documented in the link above).
The chipset is a little picky on memory configs. You should use the manual to get it going right.
It has both AMI BIOS (from around 1993) as well as Award BIOS (from 1994).
Not exactly sure if it came from the factory with CR2032 (you may find it with barrel on auction sites), but the PCB does have holes for a CR2032 (which I used, works great).
Consider this as a "mini-review" 😀
Reply 3 of 14, by jesolo
The only other 486 VLB board with a CR2032 coin cell battery holder that comes to mind is the Asus VL/I-486SV2 range of motherboards.
However, as far as I'm aware, they all had Award BIOSes.
Another benefit of these Asus motherboards is that they also have a PS/2 header (connector), which was not very common on 486 motherboards (even on later PCI bases ones).
Reply 4 of 14, by TheMobRules
The Gigabyte GA-486VS (at least the revision 8A I have) has solder points for for a CR2032 battery, which can easily be installed as long as an SMD diode is removed to prevent it from being re-charged. It looks like factory-made when done.
But as with the ASUS board, it also has an Award BIOS. Is there a specific reason you are looking for one with the AMI WinBIOS?
Reply 5 of 14, by The Serpent Rider
Which is a blessing.
AFAIK Aopen board AMIBIOS has problem with setting up dirty bit for WB L2 cache properly.
Reply 6 of 14, by alfer
TheMobRules wrote on 2020-09-21, 15:26:
Yep. 486 without WinBios is not a 486 to me. Childhood impressions and all that sentimental nonsense 😀.
I'm considering expanding the search by including anything with Dallas as well.
Reply 7 of 14, by TheMobRules
The Serpent Rider wrote on 2020-09-21, 16:00:
Yes, although to be fair SIS471 boards with Award BIOS have the same problem. But with Modbin the Award BIOS can be easily modded to fix the dirty bit issue by changing a register (there was a thread about this on the forum). I also managed to fix the issue in the VI15G by using AMISetup, but that solution only keeps the updated register as a CMOS setting.
I honestly don't know how all those manufacturers managed to mess up that dirty bit setting, maybe there was some miscommunication between board makers, BIOS makers and SIS?
Reply 8 of 14, by jesolo
TheMobRules wrote on 2020-09-21, 16:53:
If you can track down the thread, please link to it - would like to know exactly how and where to change that register.
Reply 9 of 14, by TheMobRules
jesolo wrote on 2020-09-21, 19:16:
Re: 486 cache/ram speed issue with write-back
I have done the mod on both ASUS VL/I-486SV2GX4 and Gigabyte GA-486VS. Later today I can attach those modded BIOSes or some Modbin screenshots with details about which register to update.
Reply 10 of 14, by jesolo
TheMobRules wrote on 2020-09-21, 19:33:
That would be great 👍
Reply 11 of 14, by jakethompson1
It's somewhat straightforward to modify 64KB AMI Color BIOSes in a hex editor to unhide settings. I've never attempted on a WinBIOS though. I suspect the WinBIOSes are compressed which complicates things.
Reply 12 of 14, by Anonymous Coward
alfer wrote on 2020-09-21, 16:32:
...and I thought I'd heard everything.
Reply 13 of 14, by alfer
Thanks to Deksor's advice I was able to compile a list of mainboards that satisfy my criteria. I decided to include all the options with Dallas I could find as well. First post updated.
Reply 14 of 14, by Cyberdyne
I have owned/own countless 486 systems, none of them Winbios. Amibios is the "bad boy" of 386/486 sytems. And Award is good and MR-BIOS is the holy grail.
