First post, by script-fu
I'm stuck and the best way to explain this is with pictures. So i hit F6 as soon as Win2k starts just like in XP and this is where i'm at. I have downloaded drivers all over the place and tried the kitchen sink. I have read threads here and all over the net for the last 4 days. I am truly at a loss on this one.
This is a bastardized board and i also know that the drivers say VT8237A in the picture. So i'm now wondering in all the drivers i have downloaded did one actually say VT8237 only? err
    132.09 KiB
    Win2k rolls on then gets stuck here after i fed it the drivers.
    159.14 KiB
    So here they are direct from the floppy
    166.19 KiB
    Ok Win2k wants the drivers cool
Gb GA-6BXC r.2.0 b.F4C, PIII 1.0GHz SL5QV, 768MB PC133, GF Ti 4200 64MB, VD3 2K, CT4760 & CT4860 AGP 2X
Abit KN8, 64 3400+ (754), 2x1GB G.SKILL PC3200, GF 6800GT 256MB AGP 8X
Abit Fatal1ty AN9 32X, 64 x2 6000+, 2X2GB PC6400, 8800 GTS 320MB x2 SLI
Reply 1 of 22, by script-fu
I forgot that you need to upload the pictures in reverse.
Anyway after looking at these photos again it does say VT8237 in the driver strings. So i have no idea what the issue is. I had read somewhere that the hard drives needed to be slowed down to SATA 1 with the jumpers. I didn't need to do that tho as i have those. So i yanked the SATA 2 and SATA 3 drives i was messing with and installed a SATA 1 drive.
Reply 2 of 22, by Dmetsys
Are you using the drivers that would have come from ABit or VIA? There might be a missing Hardware Vendor ID in the drivers' inf file.
http://abit.ws/page/en/motherboard/motherboar … PRODINFO=Driver
A7N8X-LA | 2800+ | GeForce2 MX400 | Audigy 2 ZS
BE6-II 1.0 | PIII-933 | Viper 770 TNT2 | Live 5.1 Value
MS-5169 | K6-2 450 | Voodoo3 3000 AGP | AWE64 Value
P5A-B | P200-S | 64MB | MGA Millennium | Yamaha 719
LS-486E | Am5x86-P75
Reply 3 of 22, by script-fu
The VIA SATA Driver v4.30g: Yep extracted that .ini and put it on it's own floppy & nada. Then i put it on the floppy you see in the pictures & nada.
Reply 4 of 22, by script-fu
Let me explain a little bit more. I have a bastardized board direct from ABIT. The mobo is actually a KV8-MAX3 so the Northbridge is a "K8T800". However my mobo does not have the sata controller at the bottom.
If you look at the KV8 PRO it has the "K8T800 PRO" Northbridge.
The boards have different NB's. Does that make a difference? IDK but i have tried all the MAX drivers too. I have used the drivers from Vogons Drivers, Phils Computer & ABIT. I have tried drivers from CNET and random places around the net.
    248.7 KiB
    My actual mobo no SATA at the bottom.
    159.74 KiB
    KV8 PRO from eBay
    322.23 KiB
    KV8 PRO Scatt
    465.79 KiB
    Proper KV8-MAX3 picture from eBay
    343.87 KiB
    KV8-MAX3 Scatt
Reply 5 of 22, by script-fu
Here is a snap of my onboard RAID. Notice it doesn't say SIL in the panel? Like this other snap whicj is in the KV8-MAX3 manual?
    909 KiB
    KV8-MAX3 RAID from the manual. However thats not what i have onboard.
    155.13 KiB
    This board is crazy it should have the SIL RAID
Reply 6 of 22, by script-fu
As far as your question i have used a few of the drivers from http://download.viatech.com/DriverDownloadSubmitAjaxSvl
I struck out on the ones i chose.
My mobo
    199.63 KiB
    Southbridge no sata controller?
    210.8 KiB
    See it's a ABIT KV8 on a KV8-MAX3 PCB
Reply 7 of 22, by Dmetsys
You can try the V-RAID 4.30c drivers and see how they work out for you.
https://www.techspot.com/drivers/downloadnow/ … ffe23c1a&file=1
Ignore the fact that it says Gigabyte. Extract the .exe with 7-Zip, and dump the drivers on a diskette. Memory serves that the southbridge variants are labelled as V-RAID, unlike standalone controllers.
Reply 8 of 22, by script-fu
Will do and I will report back in an hour? Thanks!
Reply 9 of 22, by script-fu
Choked again
Would my hard drive effect this install procedure on Win2K? It's 250 GB Maxtor SATA1 and it's all in one partition.
    137.39 KiB
    Different but yet the same.
    175.78 KiB
    Pretty much the same thing just different drivers
Reply 10 of 22, by script-fu
Well i had another idea. On the MAX3 board did the SIL drivers emulate the IDE drives? Maybe i missed the proper SIL driver in my travels.
Reply 11 of 22, by script-fu
When using the Sil drivers Win2k said no hard drive found.
    139.83 KiB
    Same deal
    152.29 KiB
    I tried the VIA's that were combined
    157.32 KiB
    Ran both Sil 3112 & 3114 w/no joy!
Reply 12 of 22, by Dmetsys
What is the controller mode to set to right now? Some southbridges will disable IDE ports, once the S-ATA ports have been assigned as Primary/Secondary ports. Then it will be seen as a standard IDE device.
Reply 13 of 22, by script-fu
I have had them set 7 ways to sunday. Here are the two settings below.
When i have both RAID setting toggled on. I can get into the secondary VIA RAID BIOS. When I have just the SATA RAID rom on same deal the VIA RAID shows at post and can be accessed by hitting the TAB button.
now
If the SATA RAID rom is off and the ONCHIP SATA RAID is toggled on the VIA RAID BIOS goes away. I truly believe this is the correct setup. So the SATA drive can be emulated as a IDE drive. If you know what i mean.
    160.1 KiB
    SATA RAID ROM
    176.41 KiB
    ONCHIP SATA RAID
Reply 14 of 22, by script-fu
I just dropped a Linux Mint disk in (Sonya 18.2) with both setting for RAID turned off. Mint would have installed but i stopped it after it correctly detected my hard drive and wanted to install.
Reply 15 of 22, by Dmetsys
Instead of running 2000 Pro, have you attempted to try Windows XP with the VIA S-ATA drivers? If XP halts at the same point, then we still have a driver to resolve. If not, then 2000 is to blame. Are you installing with Sp4 media, or a raw untouched ISO with no Service Packs?
Another question; Has the 3.5" floppy drive worked with other computers? A bad drive can also cause these types of frustrations.
Reply 16 of 22, by script-fu
It's Win2k Pro and I doubt it has any of the 4 service packs. I think i have owned that disk since day one. I didn't try XP Pro this round but I can go back and try the last drivers i posted. I will need to check if any of my XP disc have any service packs or not. I will see what i can do with the service pacts.
Yep the floppy drive is a brand new Sony USB. It works flawless across all my other PC's. Thank you so much for your time. This has been a wild one!
Also on another note Charlie over on facebook asked about lspci -nn so while i'm inside mint here are the results.
mint@mint ~ $ lspci -nn
00:00.0 Host bridge [0600]: VIA Technologies, Inc. VT8385 [K8T800 AGP] Host Bridge [1106:3188] (rev 01)
00:01.0 PCI bridge [0604]: VIA Technologies, Inc. VT8237/8251 PCI bridge [K8M890/K8T800/K8T890 South] [1106:b188]
00:0f.0 RAID bus controller [0104]: VIA Technologies, Inc. VIA VT6420 SATA RAID Controller [1106:3149] (rev 80)
00:0f.1 IDE interface [0101]: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE [1106:0571] (rev 06)
00:10.0 USB controller [0c03]: VIA Technologies, Inc. VT82xx/62xx UHCI USB 1.1 Controller [1106:3038] (rev 81)
00:10.1 USB controller [0c03]: VIA Technologies, Inc. VT82xx/62xx UHCI USB 1.1 Controller [1106:3038] (rev 81)
00:10.2 USB controller [0c03]: VIA Technologies, Inc. VT82xx/62xx UHCI USB 1.1 Controller [1106:3038] (rev 81)
00:10.3 USB controller [0c03]: VIA Technologies, Inc. VT82xx/62xx UHCI USB 1.1 Controller [1106:3038] (rev 81)
00:10.4 USB controller [0c03]: VIA Technologies, Inc. USB 2.0 [1106:3104] (rev 86)
00:11.0 ISA bridge [0601]: VIA Technologies, Inc. VT8237 ISA bridge [KT600/K8T800/K8T890 South] [1106:3227]
00:11.5 Multimedia audio controller [0401]: VIA Technologies, Inc. VT8233/A/8235/8237 AC97 Audio Controller [1106:3059] (rev 60)
00:18.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration [1022:1100]
00:18.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] Address Map [1022:1101]
00:18.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] DRAM Controller [1022:1102]
00:18.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] Miscellaneous Control [1022:1103]
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation NV40 [GeForce 6800 GT] [10de:0045] (rev a1)
mint@mint ~ $
Reply 17 of 22, by Dmetsys
script-fu wrote on 2020-12-09, 23:02:
Cha-ching, there is your issue right there. XP and 2000 Pro can't copy files from USB devices while you're in text mode setup. The floppy drive either needs to be a floppy emulator eg: Gotek, or a physical 3.5" floppy drive that is plugged directly into the floppy connector. If someone barks up that it is supported, then that comes down to motherboard. Personally, I have never had it work with any motherboard that I paired with 2000 Pro or XP.
If this is not possible for you, I would recommend slip-streaming the RAID drivers into the 2000 Pro install CD. If you don't have SP4 media, I would highly recommend slip-streaming that in as well. Some, but not all drivers may have Service Pack requirements.
Reply 18 of 22, by script-fu
I have regular ol floppy drives here. So i will plug one in a give it a shot. It does have the setting in the BIOS tho and keys right up. At this point it wont kill me to grab a regular floppy. I have them all over the darn place.
I found this on slipstreaming 2k but im not sure if i can go right to SP4 or not so any ideas on that Dmetsys?
https://www.techrepublic.com/article/create-a … -service-packs/
Thanks!!!
Reply 19 of 22, by Dmetsys
You can go straight to SP4 without any problems. DO NOT slip-stream the unsupported 5.1a Service Pack. That one was compiled by third-parties, and should be installed manually after SP4. If you are looking for media that already has SP4 built in, you can acquire it at REMOVED
