First post, by EPoX
Greetings. Im trying to add usb support on a FIC va-503+ board. i even got the manual and in it..there is a low quality picture of an optional USB board that connects to the motherboard.
( it does not look like a simple cable, this usb addon board looks like it has some components in it besides usb ports i see some capacitors and other electronic components) I tried searching on google for such addon and found nothing. I even found pics of the box, cd, and bags that this board included in the box and i did not see this usb addon card in the box.
So i came here to find out if anyone here has such addon, or how did you solve the problem to add usb support to this motherboard. If you bought another card or if you bought a PCI USB (would like to know which model and brand/chip maker did you buy)
usb is very important for me, specially for win98 so i can transfer files.
thanks
Reply 2 of 42, by Repo Man11
There is a header on the board that you can attach a USB cable to - the only difficult part is finding out the pin out of the header so you can match the cable. The VA-503+ does work with the plus series CPUs, though not officially, they are only supported by a beta BIOS, but that's more than good enough.
Here is the cable you'll need: https://www.ebay.com/itm/2-Port-USB-Rear-Pane … SsAAOSwC-tfDNu4
Reply 3 of 42, by Repo Man11
The adapter you saw in the manual is an ATX form card, for use in ATX cases. Hard to find, and expensive if you do.
Reply 5 of 42, by Repo Man11
The pin out probably matches the two five pin arrangement shown here, but you need to verify that before attaching the cable, either by a manual, or with a voltmeter.
https://www.frontx.com/cpx108_2.html
To rearrange the pins: https://www.frontx.com/head_con.html
Reply 6 of 42, by Thermalwrong
I've got the FIC VA-503A board, it shows the pinout in the manual, it is just a regular USB port backplate cable:
For the CPU support have a read of the unofficial K6 III support page: http://web.inter.nl.net/hcc/J.Steunebrink/k6plus.htm
Sadly, the link for the BIOS went away when FIC took down their FTP server, but you can find "JE4333.zip" here.
Thankfully someone runs a backup of the FTP site
Reply 7 of 42, by EPoX
thank you very much, so its not rocket science, i can plug one of those brackets that came with many athlon xp motherboards and it will work just fine. i just need to be carefull and check the pinout with a multimeter.
that is great news
Reply 8 of 42, by peg
i have the exact same motherboard and I used this: https://www.ebay.com/itm/2-Port-USB-2-0-Hub-t … -0/323846426571
The only issue with using newer usb brackets is that there are made for 9 pin keyed usb connectors. The FIC motherboard isn't keyed so you need something like what I linked above.
Also, I know you didn't ask about this, but if you need the PS2 bracket for this motherboard this one will work: https://www.ebay.com/itm/PS-2-DB25-female-Pri … rs/254093317741
Reply 9 of 42, by SETBLASTER
http://www.captainwilliams.co.uk/root/fic503.php
MODDED BIOS BY Tim Stinnett , IMPOSSIBLE TO FIND, BUT I FOUND IT, AND SHARING WITH ALL OF YOU
Reply 10 of 42, by SETBLASTER
This is a mega pack of stuff for that motherboard that i made.
It contains:
-Old websites with info and tutorials on how to fix some of the problems, specially with sound blaster cards, it has bios, drivers, etc.
-Some of the websites are not available anymore so i saved them using wayback, and i was able to get most of the files hosted on those websites too.
-For example there is a site that talks about problems with the motherboard and that site gives you a link to other 2 sites, and those 2 sites have files in it. I saved all sites to pdf and all files on the site are on the pack.
- INCLUDED ALSO THE LATEST MODDED BIOS FOR K6-iii , mod by Tim Stinnett
https://www27.zippyshare.com/v/BQevuyeq/file.html
Now if there is an angel out there in this forum.....
I would really like to have an ISO image of the original Driver CD that came bundled in the box of the motherboard, I have only seen it Once, on ebay, asking 300 dollars for it.
Reply 11 of 42, by PC Hoarder Patrol
You mean this 😀
296.78 KiB
Can't imagine its particularly rare (or valuable) - happy to write you an ISO
Reply 12 of 42, by SETBLASTER
PC Hoarder Patrol wrote on 2021-03-12, 02:36:
You mean this 😀
yeaaaaaa
is that yours???
awesome you will share the iso!
wait what model is that? the va-503+ manual i got is white
Reply 13 of 42, by PC Hoarder Patrol
Yes, these are from my retail boxed version of the VA-503+ (PCB 1.2A), bought new in 2000-2001
1009.86 KiB
I'll get the ISO written / uploaded over the weekend and link it here.
Reply 14 of 42, by PC Hoarder Patrol
SETBLASTER wrote on 2021-03-12, 03:27:
yeaaaaaa is that yours??? awesome you will share the iso! […]
You mean this 😀
yeaaaaaa
is that yours???
109.79 KiB
You can download the compressed (.7z) ISO here
https://www.mediafire.com/file/emzeteh0nidiot … RO_V4_1.7z/file
Here's the filelist & FIC company bio from the image
FILELIST.TXT
7.7 KiB
81 downloads
FIC.TXT
6.75 KiB
71 downloads
Reply 15 of 42, by SETBLASTER
PC Hoarder Patrol wrote on 2021-03-15, 04:08:
You mean this 😀
yeaaaaaa
is that yours???
thank you !!!!!
Reply 16 of 42, by Kiteless
Hey all, dusting off a months old thread here. I've been scouring the web and of course here on Vogons with no luck finding the manual for this motherboard. Any chance someone can upload a PDF of it here? Also how can I tell what rev my motherboard is? I can't seem to find it silk screened on the board anywhere.
On the plus side I've found BIOS updates, and this awesome CD Pro ISO! Super handy. Building this system to be in an interactive Quake booth at VCF West. 😁
Thanks so much all!
YouTube channel
https://www.youtube.com/channel/UCTfnRX4AWhbYJuguUcEff-g
Main Systems
NuXT
IBM 5140
486 DX4 100Mhz (Mainly DOS)
AMD K6-2 500Mhz (Mainly DOS)
AMD Athlon 700Mhz 9700 Pro (Win 98)
Pentium D 3Ghz 4670 AGP 8x (Win XP)
Reply 17 of 42, by Kiteless
Oops, found the rev it's a 1.2A. Found it waaaaaaaay down in the corner by the BIOS
YouTube channel
Main Systems
NuXT
IBM 5140
Reply 18 of 42, by PC Hoarder Patrol
Kiteless wrote on 2021-07-21, 08:19:
Thanks so much all!
Glad you found the ISO useful - you can find the manual (rev A4) here
https://www.ultimateretro.net/motherboard/man … a4777462618.pdf
Reply 19 of 42, by Horun
Thanks for CD and manual, somehow I missed this a few months ago and have two rev 1.2A.
