Reply 40140 of 58450, by cyclone3d
I bet you could use an extender for a PISA riser if you wanted to make a special case so you could have more useable ISA slots and relocate some PCI cards.
The 486 chipsets as far as I am aware support a max of 4 PCI slots. It would be fun figuring out how the PCI slots and the riser are organized so they could be labeled.
To top it off, if any onboard devices use the PCI bus then the number of available PCI slots goes down.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 40141 of 58450, by HanJammer
This Tandy Enhanced Keyboard found on local internet auction.
Beside the slightly stretched cable it looks almost like new - basically it's in perfect condition because probably it was used wrapped in it's rubber cover since it was new.
Nobody else was bidding on it. I guess people just didn't knew it's almost as good as Model M, has XT/AT mode autodetect...
Will be perfect for my 1000TL/2.
Reply 40143 of 58450, by JidaiGeki
Finally found a P4EE that didn’t cost an arm and a leg:
The attachment BCF3BE83-9A21-4247-BCF9-4603616C922B.jpeg is no longer available
Came on an MSI 865 board with 2GB RAM. Will now have to find a suitable case for this setup.
Reply 40144 of 58450, by BitWrangler
JidaiGeki wrote on 2021-08-18, 03:00:
Yeah, that's funny, the cheap ones usually have Xeon stamped on them. 😉
Reply 40145 of 58450, by Law212
Pentium 100 mhz machine for 10 bucks
Toshiba sattelite 420ct
Works, but dies out if you start any app because the fan in the back isnt working.
Reply 40146 of 58450, by Law212
Also got this for 10 bucks
P2 IBM 390
Everything seems to work well on it.
Reply 40148 of 58450, by cyclone3d
I received a NOS ASUS Socket 8 to Slot 1 adapter last week. It came with a BIOS chip and a BIOS update floppy.
The attachment PXL_20210806_221140075.jpg is no longer available
The attachment PXL_20210806_221146369.jpg is no longer available
The attachment PXL_20210806_221227060.jpg is no longer available
The attachment PXL_20210806_221238238.jpg is no longer available
YMF7x4 Guide
Reply 40149 of 58450, by SteveC
bjwil1991 wrote on 2021-08-17, 02:40:
I have a T2150CDT myself. Remove the wake battery (open the hood, remove the main battery, move the plastic anti-static piece, r […]
SteveC wrote on 2021-08-16, 19:27:
Also picked this up on eBay today for very little money - the screen has stopped working so might be fun to fix. (Seller's photos)
Toshiba Satellite T2150CDS 75MHz intel 486DX, CD drive Windows 95
I have a T2150CDT myself. Remove the wake battery (open the hood, remove the main battery, move the plastic anti-static piece, remove the 4-5 screws, and remove the 7.2V NiMH battery and clean the corrosion off before it's too late.
If you need the drivers and utilities, I'll send a link to all of it.
Oh. Before I forget, a floppy drive from a Satellite Pro 400 Series will work with it as well (tested myself since the original broke on me).
So it turned up today and I checked where you said and there's just a coin cell rechargeable battery with no leakage?
The attachment 20210818_221955.jpg is no longer available
The machine worked fine for about 15-20 mins - I got into Windows 95, even played some games, (even the battery worked for about 10 mins!) but I had a few random crashes then tried copying over some files from a CD and it froze and now I can hardly get it to boot at all- it just hangs on a bare DOS prompt even. Sometimes I've even had this screen saying the BIOS is damaged come up on a couple of boots! (Sorry for poor quality picture).
The attachment Capture.PNG is no longer available
Are these easy to take apart? Is there a heatsink on the CPU or something that might need new paste? Is there a fan that's failed even? I'm going to leave it for a bit and try again later.
Cheers,
Steve
Reply 40150 of 58450, by SteveC
SteveC wrote on 2021-08-18, 21:54:
So it turned up today and I checked where you said and there's just a coin cell rechargeable battery with no leakage? 20210818_2 […]
Cheers,
Steve
OK it appears to be a heat problem as I am running it with no issues for 15 mins or so now even doing some benchmarks with it balanced on my air conditioning unit set to 17'C! I'll strip this laptop down then and look for a heatsink that's loose or something.
Reply 40151 of 58450, by cyclone3d
SteveC wrote on 2021-08-18, 22:26:
Cheers,
Steve
The paste is either dried out / separated or the fan is bad. Heatsink could be loose as well but that would normally only happen if somebody took it apart and didn't put it back together properly.
YMF7x4 Guide
Reply 40152 of 58450, by Caluser2000
Got this PS/2 to XT keyboard thingy just in case my only XT keyboard goes pop and test other XT class systems.
Happy is me.....😉
Reply 40153 of 58450, by A001
Cooler replacement for S370 stock screamer. Also accidentally matches other heatsinks.
Reply 40154 of 58450, by CrFr
Bought this beautiful Resound New Wave MCA from Texelec. One thing I forgot, was that my IBM PS/2 P70 only has half lenght second microchannel slot. The card is an inch too long. About 155€ down the drain, damn it 🙁
The attachment IMGP2109_.jpg is no longer available
Reply 40155 of 58450, by cyclone3d
CrFr wrote on 2021-08-19, 19:18:
Looks like that fan probably vents directly to the outside of the case. Why not just relocate the fan to the outside of the case?
YMF7x4 Guide
Reply 40156 of 58450, by CrFr
cyclone3d wrote on 2021-08-19, 19:24:
There's a metal frame around that fan. And I'm not going to start modifying this mint condition machine.
edit: Another option would be to lose that SCSI-controller and SD-adapter, but after getting used to plentiful storage and ease of transferring files, going back to original 40MB ESDI hard drive is not tempting.
Reply 40157 of 58450, by luckybob
Short scsi cards are also a thing. they look like this: https://www.ebay.com/itm/271232681061?epid=13 … HoAAMXQhpdR0wZR
Reply 40158 of 58450, by Joakim
A Fujitsu Myrica with what I beleive are original parts except for the fdd, cd, HDD and peripheral.
Msi6119 v1.1
P2 @400 MHz
ATI rage pro agp 2x
Aureal vortex
The attachment IMG_20210819_220506.jpg is no longer available
Reply 40159 of 58450, by liqmat
Huh, first time I've seen that model. Love the huge red Fujitsu logo.
