Reply 40 of 495, by Skyscraper
The Matrox Millenium G100 gets 9937 FPS in 3dbench2 but the G200 only gets 1034 FPS 😁 both have 8MB SDR
It seems 3dbench2 is not the best tool to measure perfromance when it comes to Pentium 3 systems 😜
edit
I ran 3Dbench2 again with the cards that got really strange scores. There was a dot that was invisible on my LCD screen. I am using a CRT now that can display low res better.
The result for the G100 was 993.7 FPS
My Riva TNT still gets a strange score,  000.0 FPS 😁    I have remounted the card 3 times without the issue going away. FASTVID wrongly identifies the card as 4MB so that is a possible reason.
The Geforce2 MX 400 and Riva TNT2 M64 get very very low 3Dbench2 scores compared to my other cards, 167.8 FPS and 145.5 FPS.
All other tests give good numbers for all cards.
/edit
New PC:  i9 12900K @5GHz all cores @1.2v. MSI PRO Z690-A. 32GB  DDR4 3600 CL14. 3070Ti.
Old PC:  Dual Xeon X5690@4.6GHz, EVGA SR-2, 48GB DDR3R@2000MHz, Intel X25-M. GTX 980ti.
Older PC:  K6-3+ 400@600MHz, PC-Chips M577, 256MB SDRAM, AWE64, Voodoo Banshee.
