Reply 40 of 42, by gdjacobs
- l33t++
wrote:This is what i thought as well, but i have 128MB of ram, so how am i low. i dont mean to sound rude, just curious.
DOS splits your memory into several segments.
Conventional memory is the first 640k of RAM. Most titles have minimum requirements for this. I try for greater than 600k conventional.
Upper memory is the range between 640k and 1024k. Some of this is used by BIOS, but the remainder can be used for DOS drivers using DEVICEHIGH and LH (Load High) operands.
EMS and XMS memory are two standards exposing RAM above 1024k. XMS is newer and more common, but EMS is still required by a few titles.
wrote:what even is 4dos? im sorry, i dont know many of these things. i know lfn is long file names, which i would like, but i might need some assistance with optimisation (apologies)
4dos is an enhanced command interpreter, like COMMAND.COM on steroids. It does neat tricks like path completion.
