First post, by DOS-623
Greetings my excellent friends.
I have an HP t5000 thin client running freedos 1.1. im able to use fat32 usb flash drives on it and copy/play games from it. it's got a pentium 3-equivalent processor in it and 64mb of built in flash storage.
sounds great, right? well, lets talk audio. its got only a s****y pc beeper speaker, and no pci/isa slots. i have gotten the covox speech thing to work over parallel, but thats it. everything else is beep beep trash. i thought, since its got working usb ports ill get a midi to usb adapter from amazon and try out my mt-32. nope. nothing. didnt work.
id like to at least have my mt-32 to work in this, or somehow be able to use one of my many isa sound cards (like my proaudio spectrum) on this thing. i just want something better than beep beep.
any help is appreciated.
Link to usb midi thing i used: https://www.amazon.com/VicTsing-Cable-Convert … =cable+midi+usb
Reply 1 of 42, by Ampera
The issue with USB MIDI devices is that they work on USB, and likely do not have freedos drivers. Just because freedos has storage drivers, does not mean it has USB MIDI drivers.
You can try playing Windows games on it, but if you only have 64MB of storage, that may be a severe issue.
You can definitely try an ISA/PCI card. If you just want MIDI, find something with a MIDI port that most DOS games can access.
The sad fact is that most of these systems were just never made to have great sound capabilities. If you have ISA/PCI expansion then you can use a sound card, but if all you have is USB and Centronics, you're stuck with Windows USB MIDI, and Covox/DSS.
Reply 2 of 42, by DOS-623
i am able to run win3.1 off of a 4GB usb stick just fine. the thing is, i just wanted to play dos games. i want to use windows as little as possible.
i would try isa if i had a slot for it. i believe it has a pci slot on the board in an incredibly awkward spot, requiring me to remove the entire case just to see it, and keep it off if i have a card in it which i dont want. i also dont have any pci sound cards at all. only isa. i have an mt-32 that works fine with my other dos computers, so i wanted to use that or one of the spare isa cards i have.
not my photo, but here are all the ports i have on mine: http://www.vecmar.com/images/hp/HP_t5710_BACK3-4_LG.gif
Reply 3 of 42, by Ampera
What does that headphone jack do? If this system is without sound, I don't see why it would be on there.
Reply 4 of 42, by Scali
That, and a microphone jack next to it. It probably has some cheap onboard AC'97 audio or something.
Which you probably can't get going under FreeDOS.
If it's one of these, it indeed lists audio specs:
http://www.ebay.com/itm/HP-Compaq-t5000-t5520 … s-/321211615730
Audio
Output Internal amplified speaker, 1/8-inch mini, full 16-bit stereo, 44-kHz sample rate
Input mini microphone
Reply 5 of 42, by Kamerat
Scali wrote:
That, and a microphone jack next to it. It probably has some cheap onboard AC'97 audio or something. Which you probably can't ge […]
If it got a VIA VT82C686A/B based southbridge there are chances for that sound will work under DOS as one of the few onboard AC'97 solutions (also got the SiS 7018 of the 730/630 chipsets). It looks like there's a few different configured models in the T5000 series, perhaps the threadstarter could be a bit more spesific on which one he got.
YouTube channel
Reply 6 of 42, by Maeslin
From the specs he gave, it sounds like a HP t5530. If that's it, it has a CN700 Northbridge and VT8237 (or VT8237A) Southbridge. It might be worth trying with the general VIA AC97 audio driver, or maybe DOSSOUND.
Reply 7 of 42, by DOS-623
The headphone jack just outputs the beeper speaker noise. Microphone jack i have no idea since ive never used it.
i never thought about the AC'97. probably has it.
at scali, yes, it is that same kind. interesting why it doesnt list the actual sound chip and just describes the speaker.
here's a manual in case you guys want to take a look: http://www.hp.com/ctg/Manual/c00219714
mine doesnt come with the riser card unfortunately 🙁
at kamerat, i searched the above manual for "via" and came up empty handed. I dont know how else to describe it except that its an HP T5000. The plastic case says "t5000" but the sticker on there by, im guessing the ebay seller, says "HP COMPAQ T5520 PY356AA EDEN 800". ill give more info of the sticker when i can. also when i can, ill open it up again and see if the board says exactly what this thing is, if the case is or is not the original.
at maeslin, i also searched the manual for "cn700", "vt8237" and "vt8237a" and came up empty handed as well.
p.s. my english isnt the best, so if my writing is crap i apologize
Reply 8 of 42, by cyclone3d
What about using a PCI riser cable to route the PCI slot outside the case?
http://www.ebay.com/itm/32-Bit-Flexible-PCI-R … K-/382129130934
The closest you are going to find for an ISA slot is this USB to ISA adapter. They have a special version of DOSBOX to go along with it so you can use sound cards with it but not pure DOS drivers.
http://arstech.com/install/ecom-prodshow/usb2isar.html
For a PCI card with good DOS support, you are going to want either a Yamaha YMF 7xx or a Forte Media FM-801 based card.
If a Yamaha card, you may have to mod the initilization program to support the chipset. Just depends on if there is a modded version out there already that will work with it.
Not sure with a Forte Media based card as I haven't actually tested yet.
The other option would be to get a PCI to PCMCIA adapter card and use that with the PCI riser cable and use a PCMCIA/Cardbus card that has good DOS support.
Edit: You could also try an ESS Solo-1 based PCI card for DOS support.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 9 of 42, by DOS-623
Wouldnt a riser card work a bit better than a cable, since a cable could have higher chances of shorting the board?
Here's a riser card I fuond on ebay. (http://www.ebay.com/itm/Rightward-Left-Angle- … KYAAOSw32lYo0ci) hows this?
i didnt exactly want to buy another sound card, but ill search for pci yamaha ymf7xx cards
Reply 10 of 42, by xjas
If it has a serial port (DB9) you can get an old serial port MIDI interface and run SoftMPU. You'll need to use Microsoft's HIMEM/EMM386 under FreeDOS, but that generally works fine. You'll also need an interface that can convert the PC serial port baud rate to MIDI. That's probably the most game-compatible way to get MIDI out of it. Second best would be a PCI card with good drivers if you have a slot.
Reply 11 of 42, by brostenen
I am wondering, if Win98se booted in dos mode, will accept and run the usb to midi dongle from Roland. Anyone know if that is possible?
Reply 12 of 42, by Kamerat
Looks like the T5520 got USB 2.0 which means it got a newer southbridge than the VIA VT82C686A/B, so you might stay away from the YMF7xx. It also looks from the pictures I found online that this model actually lacks a PCI slot. 😢
YouTube channel
Reply 13 of 42, by DOS-623
Alright, so a quick check in the bios shows that it is indeed a t5000. i dont know why that sticker is on there, though.
In the bios it also reveals that its processor is actually a VIA Eden esp 8000. thats all it says though, regarding important info.
i also popped the hood open, which confirms what kamerat just said. no pci slot 🙁
Edit: Whoops, sorry xjas, didnt see your post there at first. To answer your question, yes it does have a db9 port. I believe I already have HIMEM installed, so I'll look around for a serial port midi interface.
Reply 15 of 42, by Kamerat
DOS-623 wrote:
So i did some googling. could i buy something like this (https://www.bhphotovideo.com/c/product/645641 … IDI_S_PDIF.html) and use it? Or do you guys have any other suggestions?
I think you need an active adapter like this as the signal levels and bitrate differs between RS232 and MIDI. Some later Roland modules supported RS232 but I don't think any MT-32 did.
YouTube channel
Reply 16 of 42, by DOS-623
Oh man, sounds like a daunting task. but im willing to try it out if its the only solution!
since i dont have any of the parts i need, it will probably take me 2-3 years to get it working (joking)
Reply 17 of 42, by Kamerat
One other complicated solution would be: Terminal PC (running SOFTMPU under DOS) -> Nullmodem cable -> PC with Windows (or linux) -> Hairless MIDI (software bridge for Windows) -> USB to MIDI adapter -> MT-32 😕
YouTube channel
Reply 18 of 42, by DOS-623
Hmmm, clever! ive got all of those resources so I'll try that idea after work.
Reply 19 of 42, by DOS-623
Ok, so I set everything up, and this is what SoftMPU spits out at me:
Serial interface detected at port 3F8
MPU-401 interrupts disabled
Error: Port trap failed. Please submit a bug report
JemmEx: exception 06 occurred at ....
And it locks up. I feel like im getting closer every second, but im not sure what to do next. I know its not emm386 or himem, but i thought jemmex was good enough?
