Reply 46780 of 47951, by Socket3
- Member
BitWrangler wrote on 2022-10-22, 18:40:SiS 315 cards... I have one that works.... just.. it's not happy on anything but 1x AGP and low res, or it goes all muddy and can drop synch. I have ascribed this to the capacitors needing replacement, which I guess will only happen when all the more interesting cards have been fixed, deployed and tweaked.
You're giving me hope here man! I'm going to stick all of them in turn in an AGP 1X board (via MVP3 maybe?) and see if there are any signs of life.
BitWrangler wrote on 2022-10-22, 18:40:BH6... solid board. Very stable. Give it it's PII 333 back and a banshee, or TNT and use for pre-98 stuff. Kinda boring really, no exceptional abilities, just a reliable donkey.
Interesting. In comparisson, the BE6-II is an overclocking beast. I run a 333MHz P2 at 500Mhz (5x100) at stock voltage on it. In fact all 4 of the 333Mhz P2 chips I have will run at 500Mhz on the BE6 (only one at stock voltage tough). Love Abit Softmenu.
