Reply 35061 of 52983, by lolo799
Predator99 wrote on 2020-07-10, 09:29:
Cool stuff!
In the lot °2 picture there was a PowerMac motherboard, could you take a close picture of it? Thanks.
Reply 35062 of 52983, by PcBytes
- Oldbie
That P5HX looks gorgeous with all that white.
Reply 35063 of 52983, by CMB75
- Member
Predator99 wrote on 2020-07-10, 09:30:
Nice POST and dual game port card, well, the mainboard is nice, too, and ... man, that's a lot of nice stuff...
Reply 35064 of 52983, by Predator99
lolo799 wrote on 2020-07-10, 09:38:Predator99 wrote on 2020-07-10, 09:29:Cool stuff!
This will go to Ebay. I have no use for it and need some refund....
Reply 35065 of 52983, by lolo799
Predator99 wrote on 2020-07-10, 10:10:This will go to Ebay. I have no use for it and need some refund.... IMG_9682r.jpg IMG_9678r.jpg IMG_9680r.jpg […]
A 9500 i see, it's a good board.
Cpu add on is a G3 something, no experience with that cpu, I think you can run some early versions of Mac OS X with those...
Reply 35066 of 52983, by imi
- l33t
Predator99 wrote on 2020-07-10, 09:29:Boxes 2 + 3:
nice nice nice nice :3
got something interesting...
Matrox G200 PCI
with a... digital port attachment?
the plug is the same as DVI, but seeing as how DVI was intruduced in 1999 and this is a 1998 card I think it is actually this earlier standard:
https://en.wikipedia.org/wiki/Plug_and_Display
anyone know for sure? ^^
edit: yep, pretty sure it's P&D, it came with an IBM T55D LCD monitor, that unfortunately broke during shipping 😒 going to have to repair that first... I got it all for 1€ so I didn't even bother to claim anything.
while the specs in the internet for the T55D suggest "DVI" in most places, this seems to be wrong, cause when you google a bit you stumble upon this:
Product Positioning:
The IBM PCI Digital TFT 2D/3D P&D -D Graphics Accelerator Adapter (10L7128) is designed to complement leading-edge P&D digital
monitors such as the IBM T55D (1024 x 768) Digital Monitor and the IBM T85D (1280 x 1024) Digital Monitor.
"10L7128" is IBM's part number for this G200 card.
Reply 35067 of 52983, by bofh.fromhell
- Oldbie
PcBytes wrote on 2020-07-10, 10:01:That P5HX looks gorgeous with all that white.
Thought so too!
Gotta be an interesting story behind that.
No doubt someone felt strongly that they should pay extra for white sockets =)
Still a green PCB tho, one would think that would have been easier to change even back then.
Reply 35068 of 52983, by imi
- l33t
white sockets was kind of elitegroups's thing back then x3
I also got a socket 5 board from them that even has white DIP cache sockets.
Reply 35069 of 52983, by Marentis
Both items are unrelated. The mainboard was bought via local classifieds from a very nice seller and the CPU was bought from an auction house.
They just arrived at the same time.
The Amazon cardboard is also just what I use for testing hardware when it arrives and not related, too 😉.
Reply 35070 of 52983, by luckybob
- l33t
Predator99 wrote on 2020-07-10, 10:10:This will go to Ebay. I have no use for it and need some refund.... […]
In the lot °2 picture there was a PowerMac motherboard, could you take a close picture of it? Thanks.This will go to Ebay. I have no use for it and need some refund....
Nice! I have one of those CPU upgrade cards. In PC terms it's an adapter that lets you put a pentium 3 into a pentium 1 board.
Reply 35071 of 52983, by Bondi
- Oldbie
These pop up occasionally on ebay. Finally got mine, NOS.
Reply 35072 of 52983, by boxpressed
- Oldbie
Bondi wrote on 2020-07-10, 18:05:These pop up occasionally on ebay. Finally got mine, NOS.
I have one of those loose. Would you mind uploading the driver disks? Thanks!
Reply 35073 of 52983, by canthearu
Picked up an old ATI 5850 for a cheap price ($30 AU)
Excellent card for my windows XP retro build, and nostolgic because it is the same (or similar) to a card I used to have years back but died.
Had to clean it and repaste it .... wasn't careful the first time and used way too much paste. Cleaned it AGAIN and did better this time.
Reply 35074 of 52983, by Bondi
- Oldbie
boxpressed wrote on 2020-07-10, 23:57:Bondi wrote on 2020-07-10, 18:05:These pop up occasionally on ebay. Finally got mine, NOS.
IMG_2399.JPGIMG_2398.JPGI have one of those loose. Would you mind uploading the driver disks? Thanks!
Sure, I'll upload the disks when the box arrives. It's now at my fried's place in US.
In the meanwhile, if you need the driver - it's here Re: PCMCIA Sound Cards
Reply 35075 of 52983, by gex85
This week I received two InWin S500 cases... in the seller's photos they looked nice and white so I was a bit disappointed when they turned out to be slightly yellowed. Also, they came with only one set of drive rails each, which sucks if I ever want to put in more drives. I will contact the seller again and see whether he still has the rails...
The second parcel was an MSI MS-5169 Ver. 2.1 Super Socket 7 ATX board with a K6-2 300 MHz on it. Was sold as untested and so far it seems to be dead. No POST, no beeps. Will investigate further tonight.
There have been better weeks...
Reply 35076 of 52983, by bjwil1991
- l33t
Maybe they used stock images for the case. As for the board, get ye a PC POST card and insert it to see if there's an error code on there and to make sure the voltages are correct.
Reply 35077 of 52983, by waterbeesje
- Oldbie
Today I received this little beauty.
The mighty Intel DX4, 100MHz pure power.
Okey, it's not a WB version, but even so it's a nice addition to replace the DX2 on my Intel Ninja motherboard.
Not entirely sure of the heat sink, maybe I'll just fit a better one... This looks like DX-50 material to me.
Stuck at 10MHz...
Reply 35078 of 52983, by EvieSigma
I personally went with an active heatsink on my DX4-100 just for a little extra longevity.
Reply 35079 of 52983, by kolderman
Anything short of watercooling is madness.
