Reply 35260 of 52868, by PC Hoarder Patrol
- l33t
yawetaG wrote on 2020-07-30, 05:25:Warlord wrote on 2020-07-30, 04:18:the air flow design on that case tho makes little since.
Why not? The bottom is likely perforated, and as you can see on the pictures there's room below most of the bottom plate. Hot air naturally rises, and gets expelled from the top.
Of course the design is also a great vacuum cleaner (unless it has good filtering in place).
It's fine for a small build; the one issue being the front-mounted PSU fan trying to push warm air out front/bottom thru the one large unfiltered opening (unless you choose to flip the fan around in the PSU). I'm thinking I might top-mount the psu (sfx or tfx maybe) in the 5.25 bay, which I don't plan on using, and adding a vented Lian Li bay cover so that'll allow warm air to be pushed out front/top (better) and also allows me to mount front intake fans in the unused PSU mount area. Apart from that, I'd expect decent airflow from the two supplied 140mm fans (both filtered), plus I can add a rear 80/90mm exhaust as well (the board I'm thinking of has plently of fan headers).
