Reply 35260 of 58403, by PC Hoarder Patrol
yawetaG wrote on 2020-07-30, 05:25:
Warlord wrote on 2020-07-30, 04:18:
the air flow design on that case tho makes little since.
Why not? The bottom is likely perforated, and as you can see on the pictures there's room below most of the bottom plate. Hot air naturally rises, and gets expelled from the top.
Of course the design is also a great vacuum cleaner (unless it has good filtering in place).
It's fine for a small build; the one issue being the front-mounted PSU fan trying to push warm air out front/bottom thru the one large unfiltered opening (unless you choose to flip the fan around in the PSU). I'm thinking I might top-mount the psu (sfx or tfx maybe) in the 5.25 bay, which I don't plan on using, and adding a vented Lian Li bay cover so that'll allow warm air to be pushed out front/top (better) and also allows me to mount front intake fans in the unused PSU mount area. Apart from that, I'd expect decent airflow from the two supplied 140mm fans (both filtered), plus I can add a rear 80/90mm exhaust as well (the board I'm thinking of has plently of fan headers).
The attachment LianLi PC-A55 airflow.jpg is no longer available
Reply 35261 of 58403, by Shagittarius
PC Hoarder Patrol wrote on 2020-07-30, 05:35:
Given that cards will be directly in the way of the top and bottom fan I think I would set both those fans on intake and let the air escape wherever it will.
Reply 35262 of 58403, by cyclone3d
Shagittarius wrote on 2020-07-30, 05:47:
Nah.. the top fan should definitely be exhaust. Hot air naturally rises and plus there will in no way be enough vent holes for the air from both large fans to escape... it will just end up making the temps inside the case hotter and the fan noise will be louder.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 35263 of 58403, by alienmannequin
devius wrote on 2020-07-28, 12:19:
alienmannequin wrote on 2020-07-28, 11:28:
... which part of the forum would be appropriate for such a journal?
This one, only a separate thread. For reference: General Old Hardware You can already find a few repair related threads in here. It's always fun 😃
Will definitely create a new thread for this machine - a little worried about what might be found, but we shall see.
mkarcher wrote on 2020-07-28, 19:40:
So, it's Compaq-specific. I have the square-shaped piggyback module - there are quite a few numbers on it that are mostly hidden. Have taken more photos of the layout of the board, as well as the oxidation of sorts - haven't done cleaning yet. Wasn't keen to remove the upgrade module yet - looks as if there might be some brittle plastic flathead bolts holding it on, however managed to wedge the camera for a partial shot of the underside.
That partial shot clearly captured the text "4MB - 32 B - M MODULE" which quite surely mean "4 Megabyte 32-Bit Memory Module". That's interesting, as the base card is a 16-bit memory card (unsurprising for a 386SX machine). So it seems the square-shaped piggyback modules might be the same for both the 32-bit base card and the 16-bit base card. And indeed, the 32-bit Compaq Deskpro 386/20 configuration guide at http://ps-2.kev009.com/ohlandl/PS2_MOST/ACROR … PAQ/2005010.PDF actually lists the part number as well. It seems not all modules are interchangable, though.
Thanks for your sleuthing. I'll be sure to document the disassembly of the board in the new thread for the journey of this machine. Assuming this card would be unlikely to PnP into any non-compaq machine, so feeling discouraged about the possibility of ever testing it, given the condition of the machine - we shall see!
Reply 35264 of 58403, by Warlord
Correct bast case scenario is to flip the top fan around as an intake so cooler outside air cools the ram and cpu. Add a fan to the back of the case as exhaust. The bottom fan is kinda irrelevant as thats a far way for air to travel to have any meaningful impact on cooling the cpu or ram It should be set on intake as well anyways. Plus with the PSU mounted on the bottom cool air for sure would never reach there, and the cool air from teh bottom would just be pulled to the psu.
In reality it's much more like this
Reply 35265 of 58403, by CrFr
CrFr wrote on 2020-07-29, 10:02:
Picked up some more junk :) […]
Picked up some more junk 😀
According to seller it is:
IBM Aptiva Model 2170-26G
AMD K6-2 450Mhz / 128MB / 4GB HDD / CDRW / NIC / MODEM
Seller says it doesn't start, nothing happens when power button is pressed. I'm hoping it is just a matter of replacing the PSU. Even if it is totally trash inside, I'm happy to have this cool looking good condition case. It seems to accept normal mATX motherboards and ATX power supply, so it would be fun case to build some sleeper system in it.
And like the seller promised, this is dead. Doesn’t start even with new PSU 🙁 There are some caps, that are somewhat swollen. Maybe I replace those, and see what happens before I recycle the motherboard.
Edit: Three largest caps were bad. Others tested ok and I didn’t swap those. Now keyboard powers on, and monitor powers on, but the screen remains blank.
Reply 35266 of 58403, by PC Hoarder Patrol
^Shame 🙁
Agree on the looks - I still have my original SCSI Pioneer slot loading DVD from 2000, chugging away happily.
Reply 35267 of 58403, by Repo Man11
I just received a GeForce3 Ti 200 yesterday. I installed it in my Soyo SY-5EMA+ to replace the ATI 9200 it had in it. I've never had one before, I had to settle for a GeForce2 Ti back then. I've been having a lot of fun with this system, the K6-2+ 550 has been a good chip so far, hitting 5x124 at 2.2 volts.
Reply 35268 of 58403, by CrFr
Turns out some previous owner had screwed around with the dip switches, setting too high voltage for the processor and fried it. I put in Pentium 166 and set the switches in correct positions and motherboard seems to work just fine. Too bad the K6-2 is f’d up 🙁
Reply 35269 of 58403, by pete8475
Got this in the mail today.
It's a Creative Labs Vibra 16X, tested in my K6-2 and works nicely.
I actually ordered this before I got the 2 free AWE64 cards so now it's not really needed, but doesn't hurt to have an extra ISA sound card in my box of stuff.
This pic is from the ebay auction, I have since moved the jumpers into the line out position.
Reply 35270 of 58403, by PTherapist
Received one of these adapters the other day for my Amgia 1200 -
Was listed as untested and sold for very little. Works great, exactly as intended.
Reply 35271 of 58403, by assasincz
Not HW but I am excited about it anyways,
Windows 3.1 for Compaq PC with UK licence, sealed (not anymore). Nice six sealed floppies.
I would like to install this on my Presario 460
The attachment 20200730_200806.jpg is no longer available
Reply 35272 of 58403, by imi
I think my supply of zip-disks for the next few years is secure.
The attachment hardware39_35.jpg is no longer available
Reply 35273 of 58403, by chrismeyer6
Wow! Where did you find them super jealous
Reply 35274 of 58403, by pentiumspeed
The fan under the cards, don't use fan there. Just vents. Use 80mm or 90mm fan blowing out, the 140mm at top, also blows out. Less noise too. Anything else conflicts.
Honestly, this case is worst design for cooling unless you have side vents on the panel, if not, draw up one and use 2 sizes of drills make grid of holes. Let it be a intake to let air waft onto cards with two fans I mentioned blowing out.
Cheers,
Great Northern aka Canada.
Reply 35275 of 58403, by pete8475
More freebies from the same friend (I've known this guy since 1997):
Several Asus USB/MIR cards (with PS/2!!!)
Various USB headers
Various audio cables
etc.
Going through the box of goodies now.
EDIT:
Took pics of the most interesting stuff.
3 x Asus USB3P
3 x Asus USB/MIR (usb only)
1 x Asus USB/MIR (usb/ps2/ir)
2 x no-name USB/MIR knock-offs (ATX form card is silk-screened on the PCB) Also one of these seems to have liquid damage / corrosion on one of the usb ports.
2 x PS/2 mouse headers
He also has an Asus P2-99B AT motherboard, but there is a blown capacitor on it, so I didn't take it.
Reply 35276 of 58403, by imi
chrismeyer6 wrote on 2020-07-30, 18:58:
someone locally was clearing them out probably leftovers from a store or music production company or something ^^
Reply 35277 of 58403, by chrismeyer6
That's a seriously nice find
Reply 35278 of 58403, by devius
pete8475 wrote on 2020-07-30, 20:02:
What??? Blasphemy!
Reply 35279 of 58403, by imi
I'd take it :p
that sure is worth to repair ^^
