Reply 40140 of 52913, by cyclone3d
- l33t++
I bet you could use an extender for a PISA riser if you wanted to make a special case so you could have more useable ISA slots and relocate some PCI cards.
The 486 chipsets as far as I am aware support a max of 4 PCI slots. It would be fun figuring out how the PCI slots and the riser are organized so they could be labeled.
To top it off, if any onboard devices use the PCI bus then the number of available PCI slots goes down.
