First post, by mr_bigmouth_502
- Oldbie
For a while I've been throwing around some ideas in my head for what would make an awesome all-around DOS gaming rig, then it hit me; "why not go for a Socket 3 PCI build?"
To be truthful I don't have a set time period for this rig, but I essentially want it to be like a souped-up 486, with the ability to play some 386 and Pentium level stuff if need be. The parts I'm thinking of going with are:
- A PCI Socket 3 board, hopefully NOT made by PCChips (I can't stand the idea of fake cache 😜) or a decent Super Socket 7 board
- As much ram as said board can take without hitting the cache limit (probably 32MB to keep it safe though)
- A Voodoo Banshee or PCI Voodoo 3, since they reportedly have good 2D performance, and I might want to mess around a bit with Glide
- A CompactFlash reader mounted in a front case bracket, so I can easily swap out cards to load different OS configurations
- A SoundBlaster AWE64, since it has decent SoundBlaster compatibility and I like the sound of the internal GM synth. I might add an SB Pro2 as well for better FM synthesis and mixer support in games like Wolf3D
- Some sort of a case that allows me quick access to the internals just by removing one panel. As much as I like the sturdiness of old AT cases, this requirement may be better fulfilled by an ATX case with AT mounting holes.
-A Pentium OverDrive for Socket 3, or an AMD K6-2/K6-3 for Socket 7
- An ISA ethernet card
For the OS, I'm thinking of going with Dos 6.22/Win3.11 as my primary OS and Windows NT4 for doing Win32 stuff. I don't expect this machine to be a beast for Win32 games, but it'll be funny to see how people react when I'm running say Wolf3D one minute, then I swap the CF card and CPU, and load Starcraft. 😁
So, what do you all think of this idea? Do you have any motherboard suggestions or anything along those lines?
EDIT: Decided to scrap the USB card and open up the possibility of going with a Super Socket 7 board.
