Vintage Hardware Wallpapers
Reply 500 of 517, by Con 2 botones
Socket3 wrote on 2022-05-23, 10:06:
I started playing around with SiS chipset boards (socket 370, socket A, socket 478) and decided I wanted a wallpaper for my firs […]
I started playing around with SiS chipset boards (socket 370, socket A, socket 478) and decided I wanted a wallpaper for my first SiS build - a Tualeron 1100 on an Asus TUSI-M (SiS 630). Hope you guys like it:
I saved the PDF file with all the different layers, so if someone would like a different resolution say 1600x1200, just let me know.
Very nice! Could you modify it to show a "K6-2 3D Now!" logo instead of "SIS"?
Reply 501 of 517, by Socket3
Con 2 botones wrote on 2022-05-23, 12:27:
Not a bad idea. Here you go:
538.49 KiB
Reply 502 of 517, by Con 2 botones
Socket3 wrote on 2022-05-23, 14:35:
Just wonderful!
Big thanks to you, Downloaded ! (I´ll use it in a Compaq Presario of mine)
Reply 503 of 517, by moknok
Rainbow 6 PC (Yes the original) and damn good book as well.
https://en.wikipedia.org/wiki/Rainbow_Six_(novel)
    104.24 KiB
    Rainbow 6 PC
| WIN98SE non OEM | PII MMX | 350Mhz | 384RAM | Voodoo3 2000 PCI | DX7 | 126GB+ | Yamaha DS-XG Sound |
Reply 505 of 517, by Intel486dx33
IBM PS/1
Reply 506 of 517, by gen_angry
This one I've had since around 2004, it was one of AMD's promotional wallpapers that they put out for the Athlon64 FX series when they first launched. Sadly it's the only one I still have.
Original res BMP converted to PNG.
edit: changed to imgur link. Not sure why uploading here obliterated the quality but... here you go 😁
https://i.imgur.com/yYsV3zB.png
(Win98SE/XP) P4 3.0c | ASUS P4P800-VM | 2GB DDR400 | x850 Pro | SBLive 5.1
(DOS6/Win95) P200MMX | ASUS P5-99VM | 64MB PC100 | S3 Trio64V2DX + Diamond Monster3D | AWE64
Reply 510 of 517, by Boohyaka
leileilol wrote on 2022-08-25, 11:46:
I'm pretty sure mai, nakoruru and dizzy are not vintage hardware products nor is their art public domain.
Saw the wallpapers before your post, cracked me up :')
They do sport some heavy hardware though
Reply 513 of 517, by gmaverick2k
maverick85 wrote on 2022-03-11, 10:12:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN"> <!-- Copyright 1998. Time Computers. --> <HTML> […]
<HTML>
<HEAD>
<TITLE>Time Computers</TITLE>
</HEAD>
<BODY BACKGROUND="../time.gif">
<P ALIGN="RIGHT">
<IMG SRC="../time1.gif" WIDTH=165 HEIGHT=47 ALT="" BORDER="0">
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
</P>
</BODY>
</HTML>
OEM logo and info
save oemlogo.png into bmp format, cant upload bmp here and save both in system folder
    4.61 KiB
    OEMINFO.INI
    179 Bytes
    5 downloads
Reply 514 of 517, by gmaverick2k
gmaverick2k wrote on 2022-09-04, 09:05:
<HTML>
<HEAD>
</HEAD>
<P ALIGN="RIGHT">
</P>
</BODY>
</HTML>
OEM logo and info
[Version]
Microsoft Windows 98 Second Edition
WinVer=4.10.2222
[General]
Manufacturer=Time Computers
Model=Time Computers
SupportURL=http://www.timecomputers.co.uk
Reply 516 of 517, by Gopher666
Those were the days 🤣. I got quite many. I remember back then having 1 main desktop PC and spending hours and days to deck out the wallpaper and icons. Now having so many retro computers, usually after I have them setup I just use the regular windows them and just running games afterwards. Too many PCs too little time 😀
Reply 517 of 517, by davidrg
Digital DECpc Wallpapers for Windows 3.1 (August-September 1993). You can get the original BMP format files along with a screensaver from here:
https://www.zx.net.nz/mirror/h18000.www1.hp.c … zips/DECBMP.ZIP
Readme File
                         DIGITAL INTERNAL USE ONLY
Digital Wallpaper and Screen Saver files for Windows 3.1
Philip Dickerson 10-Sep-93
Please send any comments, complaints, suggestions for improvements, etc
to CAPNET::PDICKERSON .
Instructions
This package needs to be manually installed as follows
(this assumes that the floppy drive is A: and that Windows 3.1
is installed in the directory C:\WINDOWS - if not, the commands
can be changed appropriately):
COPY A:DIGITAL*.BMP C:\WINDOWS\.
COPY A:SSPOLY.SCR C:\WINDOWS\.
COPY A:VBRUN*.* C:\WINDOWS\SYSTEM\.
COPY A:INFOVBX.* C:\WINDOWS\SYSTEM\.
Run the Windows Control Panel, run the Desktop control, and select
a wallpaper (the DIGITAL*.BMP files should be in the list) and select
a screen saver (Digital Polygon should be one of those listed).
    4.83 KiB
    4.81 KiB
    4.79 KiB
