First post, by Chaniyth
- Member
This is in regards to my Pentium III build.
Ok so the SB Live! Sb16 emulation is pretty bad. I have a real sb16 isa card to use. Soooo is it possible to have both a real sb16 and sb live! together in the same pc?
Sb live i wanna use for windows 98se and sb16 i wanna use for dos games. If so how do I get it setup properly? Also can the sb16 be connected to the live so I can just use 2 set of headphones? Thanks.
All the world will be your enemy, Prince with a Thousand Enemies, and when they catch you, they will kill you... but first they must catch you. 😁
