Are you missing -5volt too?
First post, by brostenen
Hi all.... (A little teaser for everyone)
I am currently investigating the possibility, to add negative 5 volt to an ATX psu, discussing this with Keropi at the moment.
Currently, we have looked into a couple of possible solutions. The one I am going by at the moment, is in the picture posted.
The motivation is to be able to use the homemade device in conjunction with something like a modern 500watt PSU.
(Look at the idea/buildingplan for it, like an early 2016 X-Mass gift for everyone)
I will not say what it is just yet. Though the plan is to provide everyone with a building plan, if this is a succes in the end.
Untill now, I have spent a total of 0.99 US Dollars. The total price for a DIY project will be a little higher.
Right now it is jumping from -5.12v to -5.18v wich is not bad, compared to a voltage monitor, found in an ATX board BIOS.
    353.8 KiB
    Small teaser!!! :-)
Reply 2 of 57, by brostenen
Koltoroc wrote:
Yes.... It will result in a device for both ATX and AT boards.
Reply 3 of 57, by Jo22
Hey, that's my multimetre! So that's where it has been all the time! 😁 (just kidding!)
But seriously, that's a cool project - really looking forward to it.. I wonder which one of the four(?) possibilities you will choose (don't tell yet). 😉
Reply 4 of 57, by PhilsComputerLab
Nice to see a low cost project to solve this. Especially the Sound Blaster 2.0 with CMS upgrade will benefit from this. One of the few cards that require -5V to work.
YouTube, Facebook, Website
Reply 5 of 57, by brostenen
Minor setback.... Blew something.... 🤣
Reply 6 of 57, by BloodyCactus
an lm337 with a couple of resistors + caps will give up a -5v 1.5A output. or chain an 905 (ie: MC7905BTG) and that will give you a direct -5V / 1A output. should cost < 2$ all up or something.
Reply 7 of 57, by brostenen
I have seen that online somewere too... The problem now, is that I can get -5volt output, the problem is to choose wich gnd I need to connect alongside the -5volt line. If I measure directly on my converter, it is spitting out -5volt. I connect the white wire to the -5v terminal. Choosing any of the black wires will draw too much through the converter I am using. It did survive. I thought I blew it because it is getting too hot. Still working though.
Reply 8 of 57, by BloodyCactus
what load/amperage can you pull from your -5v? as for gnd, unless you are doing something funky and floating the gnd or doing a virtual gnd, any ground pin should suffice.
Reply 9 of 57, by Jepael
It should not do that, maybe you are doing something wrong? Could you please show what you are doing so we can fix it before you blow something up 😀
Putting together simple negative regulator with a couple of caps should just work.
Reply 10 of 57, by PARUS
Roland LAPC-I, Yamaha 718/719, Creative Goldfinch. In all cases -5 is for Line out power, without -5 all these cards are working properly but no sound.
Reply 11 of 57, by brostenen
Well.... No ATX psu has blown up (just yet 🤣) Naaa... Just kidding.
Waiting for some feedback from Keropi, before I will post some more.
Perhaps I will get something to work with when I get that reply. 😀
If not, I will let you all know what I have done so far.
All I can say, is that I can convert +12v to -5v and draw up to 3 amp.
(that amp is acording to the spec's from the seller)
The thing I bought, might not deliver the kind of amp what it say it should.
Though being able to convert +12 to -5, makes me think I am on the right path.
Edit...
I have not seen anyone talk about what I am doing. I have not read that this
can not be done this way. Nor have I seen anyone suggesting this aproach.
Hopefully this is a way amoungst other solutions, to -5volt.
If so. It is butt-ugly cheap to make.
Reply 12 of 57, by PARUS
At this topic Short on ISA slots? Try this. about multiplication ISA slots there is also very elegant decision for getting -5 volts:
Plug into any slot and you'll get -5 in any other.
By the way jwt27 is offline for much long time. Does anybody know about him? Is all OK?
Reply 13 of 57, by Beegle
brostenen wrote:
I have not seen anyone talk about what I am doing. I have not read that this can not be done this way. Nor have I seen anyone su […]
a small male edge connector that goes into an ISA slot, takes 12v transforms it and then reflows the 5v back into the ISA bus?
Edit : Dammit you beat me to it, PARUS
The more sound cards, the better.
AdLib documentary : Official Thread
Youtube Channel : The Sound Card Database
Reply 14 of 57, by brostenen
That is a l7905acv. According to what I can find online, it used negative 12 volt and not positive 12 volt as input.
As -12v rails do not provide enough milliamp, I really need to be able to draw somewhat 500 milliamp from positive 12volt.
I guess the ISA slot solution is a simple one, taken directly from the datasheet. Looks like that. 1xregulator and 2xcap's.
Going for the regulator solution, there must be a simple solution to reverse polarity using off the shelf parts.
Once converted 12 volt positive to 12 volt negative directly, something like a 7905 regulator can be used.
Reply 15 of 57, by Jepael
Most AT power supplies had 0.3A max output from -5V anyway, and -12V outputs at about 0.5A to 0.8A.
How much would anyone need -5V for sound cards, 100mA or 200mA tops maybe?
The 7905 in TO220 case generating -5V from -12V would be perfect for that job, as long as it has ceramic bypass caps, some bulk electrolytics and enough dummy load to keep its output stable.
If you want to generate -5V from +12V, +5V, or +3.3V, you need either inverting switch mode voltage regulator or inverting flying capacitor charge pump, both of which are more noisy than linear regulators.
Reply 16 of 57, by BloodyCactus
brostenen wrote:
That is a l7905acv. According to what I can find online, it used negative 12 volt and not positive 12 volt as input. As -12v rai […]
as I said earlier, use a LM337 to feed the 7905 to get -5v. the LM331 will give you the negative voltage, which the 7905 will make an exact -5v.
or if you dont want to feed the 7905,
an lm337 with +12V input using 2 resistors of 240ohm + 720ohm will give -5v output.
http://ibration.headcrank.com/LM337Calc.php?Vout=-5&R1=240
Reply 17 of 57, by Jepael
BloodyCactus wrote:
as I said earlier, use a LM337 to feed the 7905 to get -5v. the LM331 will give you the negative voltage, which the 7905 will ma […]
It won't work because LM337 can't make positive input to negative output.
It is just an adjustable regulator that can be directly used to get -5V from -12V with correct adjust resistors, so it would be simpler to use just 7905.
Reply 18 of 57, by brostenen
Sweet...
Have not seen that one before. Thanks 😀
EDIT...
What ratings are the caps?
