Icelordetherea wrote: I wonder where i could get a really old machine that has dos-compatible card hmm.
Machines with with MediaGX CPU are often SB16 compatible (but don't do Direct3D).
Their mainboards were used in internet boxes (set-top), too.
Or look for a thin-clint. xjas had success with AdLib support.
Re: VIA-based thin client rescue
Limited support is also possible with certain PCI cards (esp. these with SB-Link).
ISA sound cards are preferable, though. The AWE64's are cheap. Literally.
And -last, but not least- some notebooks from the late 90s also included SB Pro compatible audio.
PS: Did you try VDMSound yet ? The description at sierrahelp.com fits your needs, since you use Win98 anyway. They say:
"All the Win9x users out there that find that their sound cards don't have any DOS support can at last use VDMSound.
Chris Chua took on the Herculean task of writing a VXD driver for 9x, a lot of work, with almost no volunteers to assist him
either (since Win9x is basically a dead OS, which doesn't inspire many people to write for it.)
The functionality is the same as XP. All emulation DLL's are the same (except rebuilt as ANSI as opposed to UNICODE for Win9x).
The only "different DLL" is VDDLoader. At present, there is no GUI. The VDMS LaunchPad is only for the NT version of VDMSound.
It will not work in Win9x."
