Reply 500 of 546, by ediflorianUS
16ShadesOfOrange wrote on 2021-06-20, 06:34:Hey all, I gave the screen issue another look with fresh eyes (12mo later!). It's no coincidence about the PSU short and the sc […]
16ShadesOfOrange wrote on 2020-08-22, 12:08:
- In an attempt to quieten the fans and give them 6V instead of the 12V from the PSU connector, I shorted out 2x 12V PSU fan connectors 😱(they're dead) so I'm now running 3x 12V fans in parallel from the single left-side fan connector. I opened up the PSU but can't see any obvious issues, so for now it's running
- I busted my screen somehow 😥. Seems to work OK in graphics mode eg full screen stuff like in Windows, but in DOS mode it's almost inverse, eg black is orange, the display sometimes becomes distorted/picks up interference, text becomes wobbly and almost unreadable.
Hey all, I gave the screen issue another look with fresh eyes (12mo later!). It's no coincidence about the PSU short and the screen being weird.
Ive found I've lost the 24v rail (yellow PSU wire). I guess the good news is the screen's probably unharmed 😃
I found a replacement PSU on ebay for $95USD which is steep, so I'll poke around in the PSU to see what "popped" 🚬. If anyone has a PSU schematic please hit me up!
BTW, has anyone attempted to build their own PSU or replace it with an off-the-shelf one?
I know I've seen schematic for the Toshiba T3100 PSU somewhere in service repair manual , online , if you really still need it and you can't find I can search for it.
And people , don't forget , keep cleaning your 1,44 Floppy drives , if they beep during boot-up (red/orange led) you are good to go, you just need to clean the head with cleaning floppy + alcohol , at least 10 times , 15 to be sure. then try to load floppy. (I also had initial issues with my floppy drive , but after a good clean 0 problems since).
as for HDD 3.5 if it's EIDE , you are not stuck to 100mbs, you use overlay app from floppy and setup your drive , works for older Seagate's fine. (tested fine on 4.3 gb , will test a 20gb soon - no bios mods or updates for T3100 required). I hear good success even up to WD120gb caviars also. (not sure how much can be used with drive but seem to work).
