First post, by jesolo
- l33t
I'm on the lookout for a manual or other technical guide that will provide the jumper settings for this particular model.
old thread but wonder if you ever got a response? I'm trying to muck about with the same motherboard 😀
Hi !
I have this pdf file, but it is in French, hope that helps you...
SDumas
SDumas wrote on 2020-09-08, 19:46:Hi !
I have this pdf file, but it is in French, hope that helps you...SDumas
Wow thank you so much 😀 I just saw this now..
Thank you for the file 👍
