Reply 20 of 34, by liqmat
- l33t
Youtube premiere on the Unisys Aquanta HS/6 (aka ALR 6x6) @ 6:00PM tonight Eastern time. I take you through a quick tour of these monster Pentium Pro systems.
Hope you enjoy!
Hope you enjoy!
Nice ! Interesting about any Trio64, have yet to find a board it will not work with, must be a BIOS/resource issue on the ALR dual...
Yeah most call it a cpu terminator 😀 Great looking HS+fans. 🤣 on "if I can find them", done that a thousand times but never with a 3 CPU card hahaaa.
Good explaination on the scsi SCA drives too
Over all I say Good Job ! Very informative...(and nice to know am not the only one with a little grey on top ;p)
liqmat wrote on 2021-01-12, 22:35:Hope you enjoy!
Nice system! I wonder how well my SIV utility will report it, I added support ages ago, but have never tested it. Please will you try it and post the two Menu->File->Save Local files.
I wonder how to read the CPU temperature's etc., maybe SIV will find some sensor chips.
Horun wrote on 2021-01-13, 02:13:Yeah most call it a cpu terminator 😀
After working in a datacenter for almost 15 years I've heard both depending on the sys admin you're talking to and the system they're talking about, but yes I hear terminator board more. Glad you enjoyed it.
liqmat wrote on 2021-01-12, 22:35:Youtube premiere on the Unisys Aquanta HS/6 (aka ALR 6x6) @ 6:00PM tonight Eastern time. I take you through a quick tour of these monster Pentium Pro systems.
Hope you enjoy!
What is your model number of this 19 or 20" LCD monitor with front buttons on bottom right side? Will this work with vintage games?
Very nice youtube by the way about the 6x6. I have set of intel extended express CPU board, ram card and motherboard with correct power supply. One day will find a way to turn it on.
Cheers,
Great Northern aka Canada.
pentiumspeed wrote on 2021-01-13, 20:55:What is your model number of this 19 or 20" LCD monitor with front buttons on bottom right side? Will this work with vintage games?
Cheers,
I posted about that IBM panel almost two years ago >> Re: Bought these (retro) hardware today
I am always on the hunt for 1600x1200 panels like that.
Ouch, ebay has only one seller who sells these for 500.
Cheers,
pentiumspeed wrote on 2021-01-14, 00:05:Ouch, ebay has only one seller who sells these for 500.
Cheers,
I found two so far on Craigslist. The Dell models are very good as well. The Dell 2001fp and 2007fp.
How about NEC LCD models?
Cheers,
liqmat wrote on 2021-01-14, 00:17:pentiumspeed wrote on 2021-01-14, 00:05:Ouch, ebay has only one seller who sells these for 500.
Cheers,
Locally none in this area, did get a couple of the 19" Dell cousins in last few years but they only support to 1280x1024 @75Hz good thing: they cost only $15 each.
added: And yes thanks again ! I did enjoy your video, and left a positive comment 😀
damn it, the irritational part of me wishes I had one all the more now, I didn't even know about the touch screen!
At least the sane part of me enjoyed at least looking at these things virtually.
and congratulations on your self discipline and not keeping at least 1. Shelf in my garage filled with more modern and boring servers is proof your a stronger willed man then I
pentiumspeed wrote on 2021-01-14, 02:35:How about NEC LCD models?
Cheers,
Hey, if it does 1600x1200 and cheap enough I don't care what logo is on the front, I'll take it. For my purposes, 1600x1200 LCD panels are perfect. Unfortunately, the second IBM I found on Craigslist was bad, but it came in an original box and I kept the stand as a spare so it wasn't a total loss.
For any Unisys Aquanta HS/6 - ALR 6x6 owners out there who run across this thread I solved a small puzzle with the LCD control panel. One of the machines had a very dim and hard to read display and I could not find any adjustments for it. I started to suspect a failing backlight, but then I took a closer look at the LCD logic board. Lo and behold, behind the KBD and RESET wires on the LCD logic board...
A contrast adjustment wheel.
Problem solved. Display looks bright and crisp again. Quite hidden from view so thought I would post about it.
Oh nice. I'll certainly turn mine down low so 9t lasts longer.
Looks like I am keeping the last of the five 6x6 floor models after all. There was also a sixth 6x6 rack that Luckybob has.
So since that tower is staying, I went hunting for some 80-pin SCA to 68-pin SCSI removable drawers. I already have a couple of 68-pin to 68-pin drawer models. Turns out the SCA to 68 variant is hard to find or it was for me anyway. Finally found some all aluminum NOS units and they should look nice in the ALR chassis.
I had a bunch of SCA SCSI drives from the GPPH 2018 (gave away most of them) so I needed these so I could take use of my remaining drives easily. I gave away my two RAID cages since I have zero interest in setting up a six drive RAID 5. Nothing mission critical going on over here. I may setup a RAID 1 with two of those drawers so I have some redundancy.
