First post, by Scottmm
Hope this is in the right area for some support.
I have a recently recapped MSI 694D Pro dual Socket 370 motherboard and a matched pair of modded Pentium III 1.4 Ghz chips.
My issue is that when both chips are installed, the system is unstable BSOD, MEMTEST86 displays memory errors, PC-CHECK shows the second CPU fails SMP test.
I have swapped the CPU positions but same result.
System works great and no issues if I only run 1 CPU (both tested as single).
I used to have dual 866's in this board and no issues.
Has any one had any experience with dual Tualatins in this board?
