Co-processor orientation?
Postby stalk3r » 2019-7-12 @ 10:35
Does anyone know which direction should I push this onto the socket? Pins are symmetrical i.e. it goes in any direction
User avatar
stalk3r
Re: Co-processor orientation?
Postby HanJammer » 2019-7-12 @ 10:41
See the rised dot in the corner? It should be aligned with the cutted socket corner.
User avatar
HanJammer
Postby derSammler » 2019-7-12 @ 10:42
Upper right corner of the FPU (where the additional bump is) must be aligned with the lower right corner of the socket (where the edge is cut instead of being peaked).
derSammler
Postby stalk3r » 2019-7-12 @ 11:31
Thanks guys for the help, it works like a charm. Running Quake timedemo atm, it's gonna take a while :)
User avatar
stalk3r
Postby kixs » 2019-7-12 @ 11:33
Expect around 2 FPS :lol:
My Amibay: SALE | BUY - Updated on 2019-09-26
User avatar
kixs
Postby stalk3r » 2019-7-12 @ 12:04
kixs wrote:Expect around 2 FPS :lol:
Got a staggering 1.6 FPS
User avatar
stalk3r
Postby The Serpent Rider » 2019-7-12 @ 13:09
You gotta pump those numbers up. Those are rookie numbers.
User avatar
The Serpent Rider
Postby stalk3r » 2019-7-12 @ 14:42
The Serpent Rider wrote:You gotta pump those numbers up. Those are rookie numbers.
I know... I have a lazy-ass math processor there apparently. I am open for suggestions though :)
User avatar
stalk3r
Postby The Serpent Rider » 2019-7-12 @ 14:57
Tighter memory timings, Cyrix co-processor and Cyrix 486 CPU, some late board with 486 era chipset also should help.
User avatar
The Serpent Rider
Postby stalk3r » 2019-7-12 @ 15:28
The Serpent Rider wrote:Tighter memory timings, Cyrix co-processor and Cyrix 486 CPU, some late board with 486 era chipset also should help.
I tried but timing values will go back to original on reboot... it keeps other settings though so I assume it is not the battery, rather it just does not accept certain timings? Also, this is a late Unichip board which was produced in a 486 version as well.
User avatar
stalk3r
Who is online
Users browsing this forum: AlaricD, Anonymous Coward, maxtherabbit, mt777, SSTV2 and 15 guests
