First post, by svfn
- Member
Hello! had an old PSU that with a somewhat cloudy fuse and faulty fan so aiming to get a new one. Ideally it would have 4 molex and 1-2 floppy connectors and I don't think my build requires -5V for the ISA cards.
Here's a list of the ones I can find, they are all used/refurb units and most of them I can't check the caps until I buy and open it so its a gamble:
1. AcBel E2 Power 390W - I am leaning towards this since it has 5 molex and looks good on the +5V rail, but not sure about the caps/reliabilty.
2. HP 349774-001 - 3 molex 4 SATA 1 floppy, seems like OEM unit, unsure about reliability.
3. Delta Electronics DPS-460CB - 5 molex 2 floppy? only 21A on +5V and together with +3.3V = 110W max.
4. FSP300-60THA(1) - heard good things about this but looks like it only has 2 molex and 2 SATA.
Modern units: or should I go for modern spec PSU, though lacking in molex connectors and weaker on the +5V rail.
5. FSP HE-500 - 4 molex
6. FSP HEXA+ 400 - 2 molex, will probably nee to use SATA to molex.
Build specs:
AMD-K62 350
FIC PA-2013 rev 2.1
V3 2000 AGP
SB Live PCI
AWE64 value ISA
SBPro2 ISA
Molex: Optical drive and 2x HDD
3.5" floppy
1 or 2 case fans using molex pass through
