HWiNFO support of vintage hardware
Reply 400 of 424, by mastergamma12
Mumak wrote on 2020-07-24, 07:45:
mastergamma12 wrote on 2020-07-24, 07:38:
I just noticed that for some reason, the newest version as well as the beta of HWINFO thinks that the 9700k in my htpc for some […]
I just noticed that for some reason, the newest version as well as the beta of HWINFO thinks that the 9700k in my htpc for some reason is an engineering sample when I got it from Microcenter and is an R0 based 9700k.
file.php?mode=view&id=88584
It shows "Prod. unit", but QDF number instead of SSPEC. So your CPU is OK. Shall be fixed in the next build.
Thanks 😀
Reply 402 of 424, by hwh
Results from new beta:
Had to zip the HTM because this stupid forum won't let me attach it. DBG(log).
1. Monitor is simply the saved information from some INF but the installed monitor is not this. It's a Sylvania L17.
2. This is all that shows up in sensors. I guess there aren't many sensors. Think you would have SMART or something.
3. Here is the summary now.
On the memory sheet, memory has this "detected size" but unknown "total size" for some reason...
Reply 403 of 424, by Mumak
hwh wrote on 2020-08-06, 02:48:
Results from new beta: […]
Thanks! The Trident card seems to be properly recognized now. Information like SMART will require copying a VXD within the WINDOWS folder. I don't recall now the exact path, but I think it has been detailed in the SIV thread.
As for the monitor, I will need registry dump of the HKEY_LOCAL_MACHINE\ENUM\MONITOR node.
Reply 404 of 424, by hwh
Mumak wrote on 2020-08-06, 07:49:
Thank you too. I'm not following the SIV thread, so I'll just leave it there.
Here's the MONITOR node. As you can see, there's a default, the Sony one, and then the Sylvania. However only the Sony appears as a monitor in HWiNFO, and I promise you it isn't the installed monitor. Maybe nothing you can do but FWIW.
Reply 405 of 424, by Mumak
hwh wrote on 2020-08-06, 08:33:
Thanks, I'll try to fix this in the next build.
Reply 406 of 424, by Carlos S. M.
Not really vintage, but i found an interesting misreport which happens when you try to run hwinfo on a rare EM64T enabled Socket 478 Prescott (SL7QB 3.2 GHz and SL7Q8 3.4 GHz) which reports the wrong S-Spec
61.96 KiB
Reply 407 of 424, by Mumak
Carlos S. M. wrote on 2020-08-12, 20:06:
Thanks, those SSPECs seem really rare, I can't find them in the extended/NDA Intel database nor documents.
I will update this in the next build.
Reply 409 of 424, by Carlos S. M.
debs3759 wrote on 2020-08-12, 20:51:
They were originally only supplied to one OEM, but I can't remember which one
IBM, for certain server machines
For anyone reading this thread, more info on this page: http://www.cpushack.com/2019/10/01/the-story- … m-4-64-bit-cpu/
Reply 410 of 424, by TechieDude
A mPGA478 Pentium 4 with EM64T 😳
I didn't even know these existed!
Reply 411 of 424, by Camtheman
IBM PS/2 Server 95/A HWInfo for DOS readout that @Mumak requested in the SIL thread
Few things to note:
Succesfully detected my AdLib clone and dual 2.88 mb floppy drives
VGA screen was bugged as you see in the picture, no amount of auto adjust would fix it. All other screens appear normally. Graphics card is an IBM XGA/2 1MB (standard for this machine IIRC)
After I ran it I restarted back into Windows 95 mode from real mode DOS and it appears my BIOS settings were corrupted. This doesn't happen ever and occured after I used HWInfo for DOS. Reconfiguring with reference disk of course fixed it. The particular error was "Complex configuration error or not valid"
Reply 412 of 424, by Mumak
Camtheman wrote on 2020-09-13, 03:51:
IBM PS/2 Server 95/A HWInfo for DOS readout that @Mumak requested in the SIL thread […]
Few things to note:
Thanks! I'm not sure what exactly is causing the corruption, it might be among a 1000 things in some detection. One would need to open only one particular screen in HWiNFO and check which of them causes the corruption to narrow down the search a bit.
Could you please run HWiNFO with -d -r switches to capture all screens + debug data again? I'm especially curious about the MCA screen details. Also if you could provide the Video BIOS image of the adapter, I would check how to detect/workaround it.
Reply 413 of 424, by psy_
Hi posting the HWiNFO32 log from my cyrix machine it's Cyrix 6x86MX-PR266 and is reported wrong as a PR233 :
cpu : IBM 6x86MX PR266
m/b : J-591A has AGP(x1) and pci/isa slots,
Soundcard : Sound Blaster Vibra 16 CT4180
gfx cards : diamond stealth 3d 3000 2mb virge/vx pci
net card : 3Com 3C905B Fast EtherLink XL 10/100
hdd : 2x 4gb cf card
ram : 32mb
floppy 3.5 + 5.1/4
    log.zip
    16.98 KiB
    6 downloads
Reply 414 of 424, by Mumak
psy_ wrote on 2020-09-15, 17:28:
Hi posting the HWiNFO32 log from my cyrix machine it's Cyrix 6x86MX-PR266 and is reported wrong as a PR233 : […]
ram : 32mb
floppy 3.5 + 5.1/4
Thanks, shall be fixed in the next build.
Reply 415 of 424, by vutt
I decided to upgrade from 6.13 to recent stable 6.32.
Problem - Asus sensor chip doesn't show any data. Even worse, after running it once it will kill device for any other software like Speedfan. Only restart will help.
Screenshots:
63.87 KiB
83.09 KiB
    v6_32.txt
    146.73 KiB
    2 downloads
    v6_13.txt
    45.43 KiB
    2 downloads
Reply 416 of 424, by Mumak
vutt wrote on 2020-10-12, 18:44:
I decided to upgrade from 6.13 to recent stable 6.32. […]
Screenshots:
Thanks, I think I found the problem. Shall be fixed in the next (Beta) build !
Reply 417 of 424, by Mumak
Screenshots:
Please try version v6.33-4280 Beta if it fixes this issue.
Reply 418 of 424, by vutt
@Mumak Yes P3b-F onboard sensors are now working again. Thanks!
Q: Separate one. I was wondering why your tool is giving so little info (just name, no memory sizes or clock) on my Gainward Dragon 3000 Voodoo 2 card. Is it because I'm using nonstandard 3dfxzone.it Fastvoodoo v4.6 driver or is it about my specific hw version.
Reply 419 of 424, by Mumak
vutt wrote on 2020-10-19, 09:57:
Thanks for the feedback.
Yes, that issue might be due to using a non-stanadard driver. With standard drivers it should report memory size and clocks too.
If you can post a dump of the registry "HKEY_LOCAL_MACHINE\Software" key I will look into that.
