Finished build, want to install some voodoo card, will it work?
Discussion about old PC hardware.
Postby Unrealdevon » 2019-9-11 @ 13:13
Hi!
Win98se sp3
P4 3ghz
Asus P4G800-E deluxe.
Geforce ti4600
Aureal vortex 2
512mb pc3200 dual channel.
I got a few more available pci slots except the one closest to the agp because the gf4 has a big zalman cooler.
I have no prior experience of these dual gpu configurations.
If this motherboard wich is intel 875 based can work then how does this all come together?
In the end i want to know as much as possible about this subject and its requirements, pros and cons.
Thanks!
Unrealdevon
Re: Finished build, want to install a voodoo, will it work?
Postby derSammler » 2019-9-11 @ 13:16
On that system, you could just install nGlide to play 3dfx Glide games. It's more than powerful enough for that.
A Voodoo1 won't work (and makes no sense). If at all, a Voodoo2 SLI setup would be okay, but even that is way off for a 3 GHz P4 machine.
derSammler
Re: Finished build, want to install some voodoo card, will it work?
Postby Unrealdevon » 2019-9-11 @ 13:19
I thought nGlide was for newer windows only?
Unrealdevon
Postby derSammler » 2019-9-11 @ 13:23
Should run fine using KernelEx.
derSammler
Postby Srandista » 2019-9-11 @ 13:25
nGlide isn't officially supported in Win 9x, but there are others wrappers, that are:
http://www.glideunderground.com/modules.php?op=modload&name=HTMLArticles&file=index&req=showcontent&id=89
My overkill "retro" PC - ASRock 4CoreDual-VSTA, Pentium E6500K, 512MB/4GB RAM, Radeon 9500@9700 (Softmod), ESS Solo-1 + Dreamblaster X2, 80GB IDE HDD, Win 98/XP
User avatar
Srandista
Postby mothergoose729 » 2019-9-11 @ 13:57
Unrealdevon wrote:Hi!
Win98se sp3
P4 3ghz
Geforce ti4600
Aureal vortex 2
Thanks!
My setup is very similar. My Voodoo 3 PCI works just fine. Stick to PCI cards, as the AGP is 3.3v, and it won't work for 1.5v cards like the Voodoo 3 AGP.
My motherboard has an option in the bios to switch between AGP and PCI for the graphics. In windows 98, I installed the voodoo 3 drivers first, configured the refresh rate, color depth, and resolution for the desktop, and the installed Nvidia drivers second. Whichever card I boot with, windows 98 seems to detect and load the appropriate driver (or maybe it loads both drivers every time, idk).
If you get a voodoo 2 instead, then the setup is similar, only the voodoo 2 will only work in glide games or when using a mini gl wrapper for opengl games. You'll need a monitor with two inputs or a VGA pass through cable.
mothergoose729
Postby Srandista » 2019-9-11 @ 14:10
mothergoose729 wrote:My setup is very similar. My Voodoo 3 PCI works just fine. Stick to PCI cards, as the AGP is 3.3v, and it won't work for 1.5v cards like the Voodoo 3 AGP.
Common man, it's well known, that all 3dfx AGP cards besides reference Voodoo 4 are using 3.3V from AGP slot. Even Voodoo 3 and 5. Voodoo 4 is only 3dfx card using 1.5V and only one usable in AGPx4 slots (like the one on that ASUS board, which can only accept 1.5V cards).
User avatar
Srandista
Postby Doornkaat » 2019-9-11 @ 14:38
OT: Doesn't nGlide require a DX9 card?
Doornkaat
Postby derSammler » 2019-9-11 @ 14:44
You only need a card that works with DX9 and the TI4600 does.
derSammler
Postby mothergoose729 » 2019-9-11 @ 15:32
Thanks, I mixed them up. Either way, watch your voltages.
mothergoose729
Postby Doornkaat » 2019-9-11 @ 21:14
derSammler wrote:You only need a card that works with DX9 and the TI4600 does.
Goot to know, thanks!
Doornkaat
Postby Unrealdevon » 2019-9-12 @ 10:55
derSammler wrote:Should run fine using KernelEx.
Damn!
Thanks alot for mentioning this!
Now i know what i will download after work :)
Unrealdevon
Return to General Old Hardware
Who is online
Users browsing this forum: AmiSapphire, appiah4, B.Gumble, Google [Bot], Tiido and 11 guests
