First post, by my03
I have this card inbound any day now and after googling i have found drivers for the "standard" adapter (http://ibm-pc.org/drivers/memory/memory.htm) but i wonder if those drivers will also work for the "plus" version of this card?
What is the difference between non-plus and plus btw?
Reply 2 of 7, by my03
Predator99 wrote on 2020-03-23, 15:01:
I am also currently trying to get a Rampat running:
Acculogic RAMpAT! - Anybody with a working card here?
Can you post a picture of the plus? Do you also have this Dallas-Chip?
Hi,
Dont physically have it yet but this is the actual card (from the Ebay auction)
Br
    343.48 KiB
Reply 3 of 7, by Predator99
OK yours doesnt have this Dallas but a IDT6116-LA25P CMOS
https://pdf1.alldatasheet.com/datasheet-pdf/v … T6116LA25P.html
There should also be a battery under it?
I would try the non-plus drivers first...
Do you tell us what you paid? Didnt find the auction 😉
Reply 4 of 7, by my03
Idk if it is battery backed ( but it most probably is ). I did the Dallas hacking on my ps/2 model 30 286 last weekend and it went well, but this seems to be a different beast. It looks socketed at least so perhaps some replacement can be found if needed?
The seller had it out for 90 Eur, but i made an offer for 70 and he accepted. I probably overpaid for it but i really wanted it.
Reply 5 of 7, by my03
So the card arrived today and i popped it in and started the model 30/286. It immediately counted past my base ram up to 4600 (something) KB so it does recognize the additional memory. No drivers was used, it simply worked first time.
