First post, by Sable
- Newbie
Hello! First and foremost, apologies if anything I say comes across as dumb; I've done a lot of research, but I'm still rather new to retro hardware in general - this is my first project, actually. My goal when blueprinting this build was to create an 'overkill' machine that maintains full compatibility with Windows 9x and at least moderate compatibility with DOS. Being able to dual-boot with either Windows 2000 or Windows XP would also be a nice plus.
Here's the rundown:
MB: Abit IP-95 (Compatible according to this thread on MSFN.)
CPU: Intel Pentium E5800 @ 3.20GHz
GPU: NVIDIA GeForce FX 5500 (Picked for compatibility with 8-bit palettized textures and table fog.)
Sound: Creative Sound Blaster Audigy 2 ZS
RAM: 4GB DDR2 SDRAM @ 533MHz (I'm aware Windows 9x has issues with large amounts of RAM; will be using R. Loew's patches.)
HDD: 80GB Hitachi DeskStar 3.5" SATA HDD (I'm assuming the MB has a legacy mode, as I'm aware Windows 9x has issues with SATA drives.)
Are there any glaring issues with this setup? Also, I'm not totally sure how my compatibility with DOS would be; it seems like sound should be okay with the IP-95's VIA VT8237R Plus chipset, at least according to this thread (though it appears I'll have to install modified drivers for the Audigy 2 ZS, according to this thread) and the wiki states that the FX series should be 'top-notch' for DOS.
Thanks in advance! 😀
