Man, installed the card and have a hell of a time with it. I cannot get the WDM driver from the cd to work. It would install but never see any device for playback or recording.
Now I see why VXD are installed. Got those in and it works now. Haven't played any games yet.
Since I had no idea how to do it i'll post how I got them in. Reading post http://forums.ubi.com/showthread.php/19790-Au … l=1#post3779345 for uninstalling the WDM drivers and installing VXD drivers.
Gonna qoute incase that forum goes down.
yes there are vxd drivers that work.... I think for 98 as well as 98SE. Here is problem tho. You use the vxd drivers and you wil […]
yes there are vxd drivers that work.... I think for 98 as well as 98SE. Here is problem tho. You use the vxd drivers and you will be in hell because your games will crash all the time. Creative doesn't support VXD drivers anymore and is no longer updating them so you will be using old drivers. I strongly recomend IMHO going to Windows XP 98 is a 16bit operating system and it's days are coming to an end fast. On XP my audigy 2 is a dream. If you can't get XP here is how to install the vxd drivers, you will need to remove the wmd drivers first: (Do this only if you feel confident that you know what your doing.)
1. put in you audigy 2 disk (istallation and application CD)
2. cancel out of the autorun menu
3. go to d:\audio\drivers
4. run ctzapxx
5. select driver unistall then wdm drivers and click OK
removal will take a while, don't reboot
6. reboot twice for good luck
7. repeat steps 1-4
8. select driver installation and vxd drivers and click OK
It will take a long time for drivers to install and look like systems is dead, but don't reboot just wait.
That should get you up and playing if it works in standard win 98 at all.
Although for me I had to use the Creative setup to uninstall everything first, then used that ctzapxx app to install the VXD drivers. From there you could run the creative cd setup again and install some of the other apps you need but do not install the WDM drivers.
Another tip would be disable the cthelper from running in the startup of the registry, It always causes problems for me.
@ Swaaye. Not that I know best but would just pulling out the audio/drivers folder from the cd and saving it as its own help. When setting up just use the ctapxx.exe for VXD installation make things faster?!
> W98SE . P3 1.4S . 512MB . Q.FX3K . SB Live! . 64GB SSD
>WXP/W8.1 . AMD 960T . 8GB . GTX285 . SB X-Fi . 128GB SSD
> Win XI . i7 12700k . 32GB . GTX1070TI . 512GB NVME
