brian105 wrote on 2020-06-06, 03:32:
Really? I have a 110W Mitac PSU in a SS7 PC I wanted to upgrade, possibly with a GeForce 2 card. I thought that parts of the time didn't use much power? i.e. K6-3 using 30 to 40W max, GPUs using up to 10W, etc.
That 110 W max would not be that bad if you did not have additional per rail maximums, but even if we don't take that into account :
CPU 30W (K6-2 475) https://en.wikipedia.org/wiki/List_of_AMD_K6_microprocessors
Video card 25W (can't find any formal figures for Geforce 2 GTS, but 25W for a Geforce 3 ti 200 is a figure I have seen floating around)
Motherboard 8.5w at least estimated (686B use 2.5W, could not find specs for MVP3 or MVP4, but 430TX is 1W, and at least 5W for VRMs, super IO, etc , probably too conservative)
Addition card 7W each estimated (at least 1 sound card, I imagine)
RAM 5W ( 0.1 A at 3.3V per chip typical, so about 2.64 W per 8-chip DIMM, so about 5W for 2 DIMMs)https://webcache.googleusercontent.com/search … t=clnk&gl=ca#25
Hard drive 7.1W at idle (as an example of a period drive https://www.hdsentinel.com/storageinfo_detail … l=WDC%20WD400BB)
CD-ROM 27W (0.6A on 5V and 2A on 12V https://www.recycledgoods.com/mitsumi-24x-ide … ve-crmc-fx240s/)
Total 109.6W
EDIT: And even if the GPU is closer to 10W, you're still cutting it close, IMHO .
I would say you are living dangerously .
